Mansfield Flush Valve - Plumbing Zone - Professional Plumbers Forum
Old 01-09-2012, 04:29 PM   #1
AlbacoreShuffle's Avatar
View AlbacoreShuffle's Photo Album My Photos
Default Mansfield Flush Valve
I have replaced two handles on a Mansfield toilet for the same customer in the last 3 weeks.
The handle arm is made of plastic and is breaking off right in front of the nut inside the tank.
It seems like the suction on the flush valve is a little much.
When you lift the toilet handle you can see the handle arm flex, while trying to lift the flush valve.
This home has three of these toilets and all of them seem difficult to flush.
Is there a way / trick to adjust this flush valve and make it easyer to lift up ?
AlbacoreShuffle is offline   Reply With Quote
Old 01-09-2012, 05:33 PM   #2
Michaelcookplum's Avatar
View Michaelcookplum's Photo Album My Photos
Buy a trip lever made of brass, duh! I don't think you would want to adjust the flush valve, you'll be back 3 weeks later to fix a running toilet.
Mike Cook
Michaelcookplum is offline   Reply With Quote
Old 01-09-2012, 05:40 PM   #3
I put a brass one in today.
I hope it holds up longer than a couple weeks.
Old 01-09-2012, 05:41 PM   #4
Hecho In America
Titan Plumbing's Avatar
View Titan Plumbing's Photo Album My Photos
Brass is the answer.
Titan Plumbing is offline   Reply With Quote
Old 01-09-2012, 05:49 PM   #5
www.DunbarPlumbing.com
DUNBAR PLUMBING's Avatar
The trip lever is not the problem.
It's the flush valve seal, not the trip lever that's the issue.
That seal when it gets older gets concave in shape, creating a suction to the flush valve tower. Anytime you hear "Mansfield" and "hard to flush" you should be replacing the flush valve seal.
Every plumber should know this... and replacing the internals of a mansfield with a different type of flush valve assembly is ripping the customer off big time.
Those flush valves work well if they are maintained.
The Following 10 Users Say Thank You to DUNBAR PLUMBING For This Useful Post:
AlbacoreShuffle (01-09-2012), Associated Plum (01-10-2012), ChrisConnor (01-09-2012), cityplumbing (01-09-2012), CTs2p2 (01-09-2012), Flyin Brian (01-09-2012), MarkToo (01-09-2012), Plumbdog (01-10-2012), Redwood (01-10-2012), TPWinc (01-09-2012)
Old 01-09-2012, 05:53 PM   #6
Master Pipe Layer
TPWinc's Avatar
View TPWinc's Photo Album My Photos
What he said!
TPWinc is offline   Reply With Quote
The Following User Says Thank You to TPWinc For This Useful Post:
Old 01-09-2012, 06:11 PM   #7
View CTs2p2's Photo Album My Photos
Yup spot on!!
Maybe sell them 3 rebuilds, convert to standard flapper, new tank to bowl, and fluidmaster.
CTs2p2 is offline   Reply With Quote
Old 01-09-2012, 06:12 PM   #8
Originally Posted by CTs2p2 View Post
Yup spot on!!
Thats going to be my next step.
Old 01-09-2012, 06:22 PM   #9
Oops. I do agree Dunbar if it's just the seal, 100% agree.
Although if the whole tower is gummed up from lousy water, and original needs to be changed. Converting it is not a rip-off. IMO
Old 01-09-2012, 06:27 PM   #10
Hecho In America
I changed 2 seals out the other day. It was difficult to pull the tower by hand, the seal was so gummed up. While there I installed 2 new BRASS flush handles...I do this anytime I run into the plastic handles.
The HO had no idea why it was giving her problems. I took the lid off and nearly was overcome by the chlorine...she was using swimming pool tabs...
I don't know what this is all about but this is the second time in 3 weeks I've found swimming pool tabs in the tank. On was in a 3/4 million dollar home, all 3 flushvalves broke on the second floor and they overflowed...out the front door...
ada flush valve gordos610 Plumbing Code 12 03-28-2011 11:43 PM
Mansfield Tank KCplumber Plumbing Material and Products 3 10-07-2010 07:21 PM
mansfield tank bolts fhrace General Plumbing Discussion 20 02-03-2010 07:34 PM
Briggs #75 flush valve 1703 Residential Plumbing 0 07-29-2009 07:26 AM
Moen flush valve threaderman Plumbing Material and Products 4 06-21-2008 12:10 PM
