Home two years old, homeowner noticed a drip in his mechanical room coming from this hot 3/4" pex run. This line was STRAIGHT, not kinked or stressed out. Water pressure -60 lbs. At first inspection looks like a leaking crimp ring. It was a slow drip. After cutting this fitting out, the tee broke off in hand. Ive read about the lawsuit but this is the first fitting we have seen like this! Scary to think about, the home could have flooded at any time! How many of you have seen this?
![]() ![]() Last edited by sweetness09; 03-17-2009 at 09:34 PM.. Reason: typo.. |
#2 | ||
Havent run any Zurn pex, only Wirsbo. I have had cracked fitting on the Wirsbo Plastic fittings.
UA Local 659 |
I aint CPV see in it?
All I use is Vangaurd pex down here.
My Name Is Rockstarplumber, and I Am Second.
Tallahassee Plumber Tallahassee Water line repair Tallahassee Tankless Water Heater Plumber Killearn Lakes Service Repair |
I use Viega, fittings are bronze, not brass as show in your pictures. But... that one doesn't look like a total dezinc break down. There's been lot's of press about illegal brass fittings, all over ebay with no certification. Just a good example of why you should only use quality materials.
It was probably a typo. It looks to be a 3/4" x 3/4" x 1/2" tee.
A couple of years ago I was installing a water heater in a newer manufactured (mobile) home. After I finished and turned the water on, I heard water running under the home. I crawled under the house and found a tee in the cold water line had sheared off exactly like in your picture. The PEX piping said Tuff-PEX by Uponor on it, and was joined together using brass fittings with the Oetiker clamps on it. That's the only brass PEX fitting failure I have seen. |
www.DunbarPlumbing.com
Like being able to pull the handle at the slot machine and not have to get on the gambling boat to do it.
Yeeeeeeeeehaawwwwww!!!!!!
Northern Kentucky Plumbers | ![]() YOUTUBE VIDEOS![]() | Twitter Feed | DUNBAR PLUMBING FAN PAGE
Scary. I'll have to check again what we use. The only problem we've had is the drop ear 90 splitting one month later because a nipple was either tightened too tight or they used that thicker teflon tape without regard to amount. Florida has a 12 year liability for errors and omissions.
| The Following User Says Thank You to stillaround For This Useful Post: | njoy plumbing (06-04-2010) |
It is the velocity of the water flowing through the fitting, a plumber I work with went to a code update class for his CE hours, and has learned that at 80 psi or higher pressure is causing the failure if the fitting/s, this meaning if the pressure is at 80 a prv is needed, this is always the case is far as code in concerned, I guess water moves much faster though pex then though other material. Thats all the details I have about it.
I don't see how the pressure would cause it unless the system was at the edge of it's flow limits and the extra flow being pushed thru the fixtures put the flow over the design limits.
| Tags |
| pex failure leaking zurn |
| Leaking toilet | G Archer | Residential Plumbing | 5 | 01-15-2009 07:30 PM |
| Lets All change our Avatar for the new year | Wethead | Off Topic | 17 | 12-19-2008 06:26 AM |
| Toilet Leaking | boongoon | General Plumbing Discussion | 20 | 10-29-2008 11:49 PM |
| Yard hydrant leaking | service guy | General Plumbing Discussion | 3 | 08-09-2008 03:21 PM |
| CR Zurn Polymer | Song Dog | Plumbing Material and Products | 0 | 06-27-2008 07:04 PM |
