Old 03-07-2010, 10:09 PM   #1
View express's Photo Album My Photos
Default leaking pex
I having a problem with pex leaking on the cold water line on a 1-1/2 year old repipe.
Pex cold water line starts at one end of the basement and goes to the other side to a electric hot water heater. 90's and tees along the way have started leaking under where the pipe connects to the fitting. the tees are feeding the fixtures above, no leaking from any 90s that come off the tees. There is no leaking on the hot water side. We do know that we have an acid problem that we are having tested but don't feel this is the problem because no leakish on the hot side. Here is something unusual, the well is shared with the neighbor and the pump and power is on the neighbors property.
Some have suggested I have a stray electric current either coming from the well pump or from the water heater wanting to get to ground. Anybody ever come across this problem and how would I test for it?
Thanks for your help
express is online now   Reply With Quote
Old 03-07-2010, 10:34 PM   #2
jA-Rod dat u?
Acidic water could be your whole problem.
Sounds like you need an acid neutralizer for starters and whatever else the test says you need.
"Fascism should rightly be called Corporatism, as it is the merger of corporate and government power."
~Benito Mussolini~
Lloyd Blankfein for President 2012 - Save Money Cut Out The Middleman!
Old 03-07-2010, 10:45 PM   #3
View M5Plumb's Photo Album My Photos
Try getting a hair dryer and blow warm air across those fittings and see if the problem stops? Sometimes cold temps, cold water may seep on those fittings and the hot air can seal em up. Try it and post your results.
M5 Plumbing Services llc
Serving the Portland Vancouver area
360 624 8376
'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton
M5Plumb is offline   Reply With Quote
Old 03-08-2010, 12:13 AM   #4
Where am I at?
Pipe Rat's Avatar
View Pipe Rat's Photo Album My Photos
Ya never have to use a hair dryer to keep copper from leaking. I'm just wondering though as I have never used pex, lets just say the hair dryer stops the leak??????????? What then is the permanent solution????
Pipe Rat is offline   Reply With Quote
The Following 4 Users Say Thank You to Pipe Rat For This Useful Post:
affordabledrain (03-09-2010), Bonafide (03-08-2010), Cal (03-08-2010), Plasticman (03-08-2010)
Old 03-08-2010, 12:27 AM   #5
AKdaplumba's Avatar
View AKdaplumba's Photo Album My Photos
if its wirsbo the heat would close the ring and that would be the permanent solution. pex with crimp fittings.....ummmmmm???
AKdaplumba is offline   Reply With Quote
Old 03-08-2010, 12:34 AM   #6
Not necessarily but will clue you in to some better solutions to maintain the product. Insulation etc id req'd. Sounds silly but its effective. Next step is to re-apply a new joint in the area.
360 624 8376
Old 03-08-2010, 09:39 AM   #7
I have about 12 fittings leaking on the cold water side, As we know when you have an acid problem it will show up on the hot water side first. As far as heating up the fittings I have 1/2" 90s about a foot away from the tees without any leaking. So why would acid only eat up certain fittings, why would condensation only effect certain fittings. The fittings involve are in a straight line from well to water heater. I think this problem is deeper then the usual.
Old 03-08-2010, 10:41 AM   #8
Sand in the water,acid water or bad crimps. Now go cut it out and see why.....its easier than guessing.
Old 03-08-2010, 10:59 AM   #9
Ron
Ron's Avatar
When was the last time you calibrated your crimper?
The Following 2 Users Say Thank You to Ron For This Useful Post:
Protech (03-08-2010), Redwood (03-08-2010)
Old 03-08-2010, 02:37 PM   #10
Protech's Avatar
Is it a pinhole leak in the actual brass fitting or is it leaking between the pex pipe and the brass fitting? If it's a crimp system and it's leaking at the joint, then the crimpers will need to be adjusted. Any crimps that have been leaking for more than a day or so must be cut out.
If the joints are cold expansion joints (wirso/uponor) then they may have been held open to long in cold conditions and the hair dryer trick may work.
If you have pinhole leaks in the brass fittings than you should have used plastic fittings instead of brass due to the aggressive water. You could install and acid neutralizer as well. The trouble with reliance on neutralizers is that every time it falls out of maintenance, the water system starts getting damaged irreversibly.
Protech is online now   Reply With Quote
The Following User Says Thank You to Protech For This Useful Post:
More leaking Durapex TheMaster General Plumbing Discussion 55 08-19-2009 10:34 AM
What's leaking? Protech Plumbing Pictures 16 07-23-2009 09:21 AM
Leaking toilet G Archer Residential Plumbing 5 01-15-2009 07:30 PM
Toilet Leaking boongoon General Plumbing Discussion 20 10-29-2008 11:49 PM
Yard hydrant leaking service guy General Plumbing Discussion 3 08-09-2008 03:21 PM
