I have a customer who has a leak from the exposed lead water service in the basement. Wiping a new joint is not an option but am considering the use of a Lead-Loc fitting to make the transition to copper.
Has any one had any experience with this type of fitting. |
I have used ford couplings i buy locally. you have to get the right one for the thickness you are working with.
http://www.fordmeterbox.com/pages/J_Section/Jsec.htm |
| The Following User Says Thank You to Plumber Jim For This Useful Post: | PLUMB TIME (03-15-2010) |
Anytime.
It's prolly been 20 years since I wiped a joint and even then I wasn't that good at it. My feeling was that if I could get by with the coupling, re-round and file, and prevent compression failure, it would be one and done.
I don't want to risk losing the small portion of pipe that I have to work with ![]() Thanks for the responses. |
around here we can only buy couplings in straight sizes, so you might have to buy two diffrent couplings for transition to copper and just steal the washer out of one to put in one side of the other. and oh yea don't forget to restrain it from thrusting.
#9 | |
The right hand part is for lead drainage to IP 1-1/2" both ends. The left hand part of the photo is for 5/8" lead to 3/4 IP. To use you slipped the end with the nut over the lead, then with a turn pin you flared the lead out, then with a ballpeen hammer you flattened the lead against the flange, then you took a rasp and filed the excess lead to the diameter of the fitting. Finally you coupled to the other end, the lead you hammed flat became the gasket and the pressure caused by tightening the nut created the seal. Enjoy the way of the past. Yep I still have a couple of them.
Bill Parr LMP www.parrsplumbing.com click on ... A little of this and a little of that |
| The Following 2 Users Say Thank You to PLUMBER_BILL For This Useful Post: | PLUMB TIME (03-16-2010), RealLivePlumber (03-16-2010) |
I get nervous messing with lead that old. We have homes here that have lead services, and usually there is not much protruding through the wall.
Maybe you better send Bill a plane ticket, and tell him to bring some of those fittings! ![]()
RealLivePlumber You can make it happen, you can watch it happen, or you can wonder wtf happened. Phil Harris 2009 |
| 100% lead free, and 1000% more expensive | TheSkinnyGuy | General Plumbing Discussion | 27 | 07-02-2010 09:12 AM |
| Recycled lead with antimony for lead and oakum? | Protech | General Plumbing Discussion | 30 | 02-28-2010 11:37 PM |
| Pulling apart lead and oakum joint | RDW 920 | General Plumbing Discussion | 17 | 05-23-2009 09:39 AM |
| Lead/oakum joint | GrumpyPlumber | Plumbing Pictures | 17 | 09-18-2008 07:28 AM |
