Hello, I posted on another thread a few days ago. Anyway, I have more details. We have a customer in a house and the water has an egg smell. Already changed Anode, then he got a new W/H. Smell was gone for a few weeks. It is back...The smell is only on one side of the house, only hot water! He has a well. P.S. I tried to be as detailed as possible, my husband is the plumber.
#2 | |
There are 3 kinds of common anodes out there. Which one did you replace the factory magnesium anode with?
You said a new water heater was installed. Does that one have the factory magnesium anode still in it? Is the water being chlorinated? If not, install a chlorine injector on the well system. Change the anode to a zinc/alum/tin anode and flush the heater and all water pipes with heavily chlorinated water. The idea is to sterilize the water distribution system downstream of the chlorine injector and then the chlorine injector will keep it clean after sterilization is done. Temporarily cranking up the heater temp to kill any possible traces of bacteria is prolly a good idea to. |
| The Following User Says Thank You to Protech For This Useful Post: | Redwood (08-24-2010) |
On a side note.....I had a customer that was complaining of stinking water. I took the call and went out to inspect. She took me to the bath that they smelled it in when they took a shower. She ran the hot water and no smell showed up.......the room steamed up and then the STINK showed its face. I leaned over and smelled the towels hanging on a few robe hooks. The towels had soured to the MAX from being wet too long.....the steam kicked the smell up enough for you to smell it. Humidity will make stinky things stink worse.
| The Following User Says Thank You to TheMaster For This Useful Post: | TheSkinnyGuy (08-30-2010) |
You can rid the rotten egg odor either of two ways: 1) chlorinate system or 2)raise temperature to at least 140 degrees F. Both by themselves will kill the hydrogen sulfide bacteria. If you bleach, add 1 gallon of household bleach for every 25 gallons of W/H tank capacity. Regardless of which method employed, you MUST draw water to EVERY hot fixture in house. You need to kill bacteria in not only the tank but in all the hot lines as well. If you use bleach, after running hot water taps until bleach is smelled at fixture outlet, close faucet and let stand for 2 hours. Then you have to flush tank and lines completely. I prefer to hike up the thermostat. But caution is in order; make certain no children will be in home to open a faucet and burn themselves. The last thing we want is a child to get burned from the very hot water. I hope this helps. By the way, I've never had to change an anode rod to remove the smell. Bleach or very hot water (minimum 140 degrees F.) will do the trick.
Hire a licensed master plumber. |
| The Following User Says Thank You to Tommy plumber For This Useful Post: | plumbingintexas (08-19-2010) |
I installed a manganese greensand filter for a friend that had a lot of iron in his well, inadvertently, the hydrogen sulfide smell disappeared as well. I have used manganese greensand filters two more times since then and the smell goes away each time. Must be killing the bacteria through oxidation? Any thoughts?
| The Following User Says Thank You to plumbear For This Useful Post: | plumbingintexas (08-26-2010) |
#10 | |
Paul
Rocksteady Plumbing Serving San Luis Obispo County (805) 237-7625 (ROCK) http://rocksteadyplumbing.com/ |
| The Following User Says Thank You to rocksteady For This Useful Post: | plumbingintexas (08-26-2010) |
| Tags |
| smelly water |
| Smelly water; well water and Anode rods | Indie | General Plumbing Discussion | 27 | 12-28-2010 08:46 AM |
| Smelly water | plumbingintexas | Boilers, Hot Water & Steam Heating | 9 | 09-26-2010 07:43 PM |
| Pelican Water Technologies - Water Softener? | rocksteady | General Plumbing Discussion | 2 | 03-05-2010 02:04 PM |
| Water temp and water heaters | TheMaster | General Plumbing Discussion | 105 | 09-16-2009 08:25 PM |
| Sewer Water Or Rain Water? | smellslike$tome | General Plumbing Discussion | 3 | 03-19-2009 07:48 PM |
