GC told me PVC waste and pex supply.
HO says cast iron and copper HO footing the bill Cast iron and copper it is. Never done cast in a house, though I have done many outside drains with it. HO wants cast so he dont hear the water running. I talked to my dad and he suggested to do the horizontal and vertical with cast, but then switch to PVC at the traps. Makes sense, you will not hear the water running through the traps anyway. vents I will do in PVC as well. I am going to take some pix later on after its done. First time for everything
We have done several residential houses like that. It looks pretty when you're done, black waste lines, and white vents.
It can help win bids to. Give a price for all cast iron then another price for cast iron/pvc with an explanation. If they bite on the PVC vents your price is pretty much guaranteed to be competitive. That is unless that is the standard where you are, around here we seem to be the only company that's caught on to that trick yet. |
We use a cordless screw gun with a 5/16 (I think) socket in it. Using the torque wrench you can calibrate the screw gun to the correct torque. It's not a bad idea to check after ever five clamps or so that the screw gun is still correct or to even go over every clamp with the torque wrench. Saves a lot of time over tightening them all down with just the torque wrench.
#6 | |
Ridgid tool user
Ridgid |
I have a "T" torque wrench already. I always use it foe bands because if I use a 6 way screwdriver it ruins the end, or I overtighten the band.
#9 | |||
UA Local 659 |
| falling cast iron | Bill | Plumbing Safety | 9 | 07-05-2010 07:12 PM |
| Gray Cast | Plumberman | Commercial Plumbing | 14 | 01-06-2009 01:23 PM |
| Tie into cast iron | Bill | General Plumbing Discussion | 20 | 09-11-2008 01:07 AM |
| Ductile Iron | Plumberman | Plumbing Pictures | 4 | 08-10-2008 09:38 PM |
