Old 03-12-2010, 07:10 PM   #1
Ron
Ron's Avatar
Default Caulked Cast Kitchen Sink On Tile
So on a job where who ever set this cast sink caulked the underside thick, making it almost impossible to remove without causing any tiles to crack or break, owner did not want to go there opted not to attempt it at this time.
I don't find many caulked this bad and not able to remove them with no damage to the tiles.
Lets hear some tips on getting that sink out with out cracking, chipping, breaking or causing any of the tiles to come freed up...
Old 03-12-2010, 07:37 PM   #2
ChrisConnor's Avatar
View ChrisConnor's Photo Album My Photos
There used to be a product that would soften caulk. I took a while, but it worked. Cleaning up the melted caulk would be a mess.
I used a pvc cable saw to get a toilet up yesterday, maybe that could work.
You could also buy one of those kits like they sell for removing windshields. It's kinda like a pvc cable saw, but the handles are removable and more ergonomic or maybe one of those windshield removal knives, they make a cold knife and a hot knife that has a heated blade.
ChrisConnor is offline   Reply With Quote
Old 03-12-2010, 08:02 PM   #3
SummPlumb's Avatar
View SummPlumb's Photo Album My Photos
Could you not cut it with a razor?
"The Plumbing Guru"
SummPlumb is offline   Reply With Quote
Old 03-12-2010, 08:09 PM   #4
Ron
Ron's Avatar
Tried, it was set solid, I don't think there was away to accomplish it without damage to the tile, I tried shape putty knife and a heated putty knife, looking up on the bottom side you could see it was set into a full ring or caulking, oozing out around the edges.
Old 03-12-2010, 08:33 PM   #5
SummPlumb's Avatar
Well, sometimes you have no choice. If they want to upgrade, sacrifices have to be made.
"The Plumbing Guru"
Old 03-12-2010, 08:41 PM   #6
Cal
Cal's Avatar
View Cal's Photo Album My Photos
May i suggest ;
http://www.fein.de/fein-multimaster/us/en/main/
I have the cheap , Dremel version ,,,, need to spend the big $ and get the Fein Multimaster
"The unforgivable crime is soft hitting. Do not hit at all if it can be avoided; but never hit softly."
Cal is offline   Reply With Quote
The Following User Says Thank You to Cal For This Useful Post:
ChrisConnor (03-12-2010)
Old 03-12-2010, 08:43 PM   #7
Bill's Avatar
I have used a razor knife, a string saw, and sometimes I use caulk softener.
Virginia Plumbing Codes
Virginia Department of Licensing
Everything in the known universe is governed by "Cause and Effect", there is no getting around it. Think about what you do before you do it.
Old 03-12-2010, 09:12 PM   #8
futz's Avatar
View futz's Photo Album My Photos
Get a couple thin, sharp putty knives - one narrow and one wide. Get a couple spares too. Try just forcing them under (use a wobbling action - use those corners to cut) to cut the caulking, sometimes with a little help from a thin screwdriver as a wedge. If that won't work, hammer them under to cut the caulk (you'll usually destroy one knife per sink - the reason for the spares). As you get more cut you can add more wedges to put a bit of tension on the caulking and hold the sink up so the caulking is easier to cut. Works great. I've removed many different types of glued in sink that way.
futz is offline   Reply With Quote
Old 03-12-2010, 10:12 PM   #9
SharkBite Certified
OldSchool's Avatar
View OldSchool's Photo Album My Photos
you could take a hanmer and smash the cast iron sink into bits
Originally Posted by U666A View Post
My bad mood will fade, your ignorance will last a lifetime...
OldSchool is offline   Reply With Quote
Old 03-12-2010, 10:21 PM   #10
niteowl's Avatar
View niteowl's Photo Album My Photos
i use a milwaukee heat gun to soften caulk. not hot enough to damage. i also use an o-ring pick to remove caulk. i use small wood wedges as i go, careful not to raise up sink to much at one time. this also works on urinals and wall hung lavs.
niteowl is offline   Reply With Quote
Washing Machine into Kitchen Sink Drain DUNBAR PLUMBING Plumbing Pictures 45 09-01-2010 09:26 PM
Need Help buying Pump for kitchen sink mikele191 Residential Plumbing 4 02-28-2010 10:39 PM
Tile contractor Hack TheMaster General Plumbing Discussion 45 11-12-2009 11:06 PM
tile guy complaint kellybhutchings General Plumbing Discussion 16 07-26-2009 07:39 PM
Kitchen sink drain re-pipe TheMaster Plumbing Pictures 17 06-25-2009 10:38 PM
