2 water heaters. tandem or series? - Plumbing Zone - Professional Plumbers Forum
Old 12-18-2011, 11:13 PM   #1
Master Plumber
rob the plumber's Avatar
View rob the plumber's Photo Album My Photos
Default 2 water heaters. tandem or series?
How do you guys plumb 2 heaters? I always run them tandem. I think its best for both heaters to be fed and worked evenly. When run in series, one heater is basically just a storage tank. You also can shut down and remove one heater when run tandem. In series you are sol.
Pros, cons?
rob the plumber is offline   Reply With Quote
Old 12-18-2011, 11:32 PM   #2
ChrisConnor's Avatar
View ChrisConnor's Photo Album My Photos
Pros, cons?
I prefer parallel ( which I think is what you called tandem). Just gotta keep your piping lengths right.
ChrisConnor is offline   Reply With Quote
The Following User Says Thank You to ChrisConnor For This Useful Post:
JERRYMAC (07-04-2012)
Old 12-18-2011, 11:44 PM   #3
Hecho In America
Titan Plumbing's Avatar
View Titan Plumbing's Photo Album My Photos
Depends on the needs.
Titan Plumbing is offline   Reply With Quote
Old 12-18-2011, 11:56 PM   #4
View greenscoutII's Photo Album My Photos
Parallel... Always parallel..
Faster, better, cheaper.....
Pick two........ You can't have all three.....
greenscoutII is offline   Reply With Quote
The Following User Says Thank You to greenscoutII For This Useful Post:
plumber666 (12-20-2011)
Old 12-19-2011, 12:28 AM   #5
markb's Avatar
View markb's Photo Album My Photos
Reverse return or parallel. Depends on which is easier.
Sent from my iPod touch using PlumbingZone
Never give in. Never give in. Never, never, never, never--in nothing, great or small, large or petty--never give in, except to convictions of honor and good sense. Never yield to force. Never yield to the apparently overwhelming might of the enemy.
- Winston Churchill
markb is offline   Reply With Quote
Old 12-19-2011, 03:55 AM   #6
I'm right your wrong
easttexasplumb's Avatar
View easttexasplumb's Photo Album My Photos
Just install one tankless, it will work.
easttexasplumb is offline   Reply With Quote
The Following User Says Thank You to easttexasplumb For This Useful Post:
cbeck (07-04-2012)
Old 12-19-2011, 07:00 AM   #7
View beachplumber's Photo Album My Photos
When running im parallel if your piping isn,t the same length will one heater not work more than the other. I realize in series the first tank is gonna run more.
I usually run in series (electri)
beachplumber is offline   Reply With Quote
Old 12-19-2011, 02:09 PM   #8
Master Pipe Layer
TPWinc's Avatar
View TPWinc's Photo Album My Photos
I would think that there would be a little more to balancing the draw on parallel installs than just pipe length. Difference in flow restriction in the heat traps and dip tube will affect the balance won't it. There could also be and issue with sediment build up, which will be higher on a parallel install, due to spliting the flow rate in half. Of course it does depend on the application and why you are useing two heaters and not one. You are not SOL when it comes to removing 1 heater out of a series system if they are plumbed correctly. I install all series heaters with a bypass.
TPWinc is offline   Reply With Quote
The Following 2 Users Say Thank You to TPWinc For This Useful Post:
422 plumber (12-27-2011), mccmech (12-19-2011)
Old 12-19-2011, 08:18 PM   #9
Master Plumber
The bigger houses I've done are usually 2 50 gallon power vent heaters. I think the piping looks flossier in tandem, and if one heater fails, you can shut the ball valves and remove the bad heater while leaving hot water available. I think one heater does all the work when plumbed in series.
The Following User Says Thank You to rob the plumber For This Useful Post:
Old 12-19-2011, 11:00 PM   #10
Master Pipe Layer
TPWinc's Avatar
One heater doesn't do all the work, but it does do alot more than the other. Because of this the second heater recovers quicker. You can remove one out of a series and leave hot water available if plumbed correctly. The tandem or parallel is a cleaner and easier install though.
water heaters protekplumbing Boilers, Hot Water & Steam Heating 12 03-28-2011 12:37 AM
Water Heaters....IPC PlumberPete Plumbing Code 33 03-09-2011 09:38 PM
Water heaters in series. . . UALocal1Plumber Commercial Plumbing 9 02-05-2011 03:54 PM
Water temp and water heaters TheMaster General Plumbing Discussion 105 09-16-2009 08:25 PM
Hot Water Tanks - Parallel versus Series Scott K General Plumbing Discussion 10 03-05-2009 01:36 PM
