SharkBite Certified
Hey everybody I wonder what your opinion is.
Who is responsible to install the Thermostatic Mixing Valve on the hot water tank. Is it a)the plumber doing the new house b) or the hot water tank installer. and In a hot water tank replacement or change out A) is it required to install a Thermostatic Mixing Valve on the replacement tank B) fine not to install a Thermostatic Mixing Valve because the house is exisiting |
#2 | |
and B
SharkBite Certified
A 1st Question
B 2nd Question
SharkBite Certified
Actually we have a real problem with this up here... we have companies that rent out hot water tank to homes and they think they dont have to install mixing valves on any of their tanks..
The only time that it comes into question is on new construction when the inspector catches it. To me I feel that want ever equipment is being installed it should be installed to meet code... but these hot water tank installers argue that it is the plumbers job... It turns out to be quiet the pissing contest |
All water heater installs and replacements require a permit here.
SharkBite Certified
I think even with a change out it should have to be installed to the current code.
Just like venting pipe for the hot water tank has to be changed if it doesn't meet code...so should the mixing valve also be upgraded or added on to the system. But every time the hot water tank installer change out a tank they never install a mixing valve |
SharkBite Certified
It would be nice if they made permits for that here but we only have building and plumbing permits.
code says...... new or replacement water temp must be limited to either 120 or 130 depending on your local amendment. Watts and Sparco both recommend an ASSE 1070 compliant tempering valve with hot temp limiter. Watts further recommends that ASSE 1070 tempering valves be located at fixtures that provide hot water and that the tank tempering valve be set to 160 to kill off legionella bacteria. Though I know of no states that currently are requiring this, I suspect it will not be long before it becomes mandatory. So here's a chance to make some bucks yes
So little time, so many asses to kick Protect your trade, think before you buy |
| The Following User Says Thank You to nhmaster3015 For This Useful Post: | Protech (08-23-2010) |
Even Electric ???? Really ??
"The unforgivable crime is soft hitting. Do not hit at all if it can be avoided; but never hit softly." |
| Mixing Valves | belu0501 | Plumbers Swap | 4 | 08-04-2010 09:44 AM |
| do all thermostatic mixing valves lag. | justin | General Plumbing Discussion | 29 | 07-21-2010 08:44 AM |
| thermostatic valve not mixing water temps | laurob | Residential Plumbing | 4 | 04-13-2010 05:13 PM |
| Piping Hot water tank recirc with thermostatic mixing valve | Scott K | General Plumbing Discussion | 4 | 12-16-2009 07:07 PM |
