GRANTED ... Codes require that relief valve discharge must not be trapped. IE: The closed post this A.M. by the HVAC Guy.
But are there any alternatives? Personally I would not want to be standing in line of the 3/8" hole. eg.
Bill Parr LMP www.parrsplumbing.net For my alternate web site, click on ... A little of this and a little of that |
#2 | |
Not under UPC Code
UPC says it has to be piped to the outside or to an indirect waste receptor.
Ok sounds good. Try this next time you install one....hold open the relief valve for about 10 minutes and see if the pan will take it out as fast as it comes in. I assume your pan drain is 1" gravity and the discharge pipe is 3/4. I think they should go out independent but hey I dont write the code.
| The Following 4 Users Say Thank You to TheMaster For This Useful Post: |
Heres how my code works. You can pipe a water heater pan in 1" but the relief line must go out independent. If you pipe the water heater pan drain with 1.5" pipe you can install a combo in the drain pan piping and dump the relief line down into it but it still cant dump directly into the pan itself.
| The Following User Says Thank You to TheMaster For This Useful Post: | service guy (01-15-2010) |
Plumbing Contractor
Always Something
I do 1" PVC from the pan and 3/4 copper from the discharge to the exterior terminated between 6 & 24" above the grade. I don't know whatthe distance req's for the pan drain is. There may not be a tee - a valve of any kind and the ID may not get reduced. I also seem to remember that there may not be threads at the termination point of the relief line. OH..OH, the discharge line may not be located in an area where damage can occur should the valve release!
"It's now. You just go for it now and you worry about the future and the past later." -Steve Nash And when I leave come together like butt cheeks -Grits n Gravy |
| Relief Valve Piping | JJOU812 | Plumbing Code | 7 | 01-15-2010 11:06 AM |
| Piping Hot water tank recirc with thermostatic mixing valve | Scott K | General Plumbing Discussion | 4 | 12-16-2009 06:07 PM |
| Vacuum relief valve | ILPlumber | Commercial Plumbing | 3 | 11-01-2008 08:53 PM |
| Gas relief | Bill | Off Topic | 11 | 08-31-2008 09:13 PM |
| tankless relief valve | smellslike$tome | Residential Plumbing | 34 | 07-25-2008 01:19 AM |
