Old 02-28-2010, 11:19 PM   #1
younger-plumber's Avatar
View younger-plumber's Photo Album My Photos
Send a message via AIM to younger-plumber
Default 3/4" pex pipe in the ground?
I have met a plumber who tells me stories of how they put 3/4" px pipe in the ground for main lines...is that legal? or safe? just curious because i was always taught poly and pvc...
LIVN AND LEARNIN
younger-plumber is offline   Reply With Quote
Old 02-28-2010, 11:20 PM   #2
Ron
Ron's Avatar
Code approved here.
The Following 2 Users Say Thank You to Ron For This Useful Post:
M5Plumb (03-04-2010), Protech (03-03-2010)
Old 02-28-2010, 11:22 PM   #3
It may just be me..im just used to the much thicker tougher looker black piping as apposed to the slender pipe.
LIVN AND LEARNIN
Old 02-28-2010, 11:23 PM   #4
Ron
Ron's Avatar
Pex pipe has the same ID as Copper, we do run 1" or larger for our water service lines.
Old 02-28-2010, 11:23 PM   #5
I aint CPV see in it?
ROCKSTARPLUMBER's Avatar
View ROCKSTARPLUMBER's Photo Album My Photos
Poly? What kind of poly?
ROCKSTARPLUMBER is offline   Reply With Quote
Old 02-28-2010, 11:31 PM   #6
SummPlumb's Avatar
View SummPlumb's Photo Album My Photos
I run pex for all residential main lines. No joints, easy to fix when the power company cuts it. It is easy to tie in on both ends. No waiting on glue to dry.
"The Plumbing Guru"
SummPlumb is offline   Reply With Quote
Old 02-28-2010, 11:34 PM   #7
futz's Avatar
View futz's Photo Album My Photos
I use pex for water services and in-building underslab lines routinely. Pex IS polyethelyne - basically it's just cooked a different way to cross-link it, and died a different color. Don't tell anyone I told you this, but in a pinch you can crimp a pex ring and fitting on black poly tube, providing it's the right grade (wall thickness). Inspectors would hate that though, so don't do it.
For 1/2" in-house underslab waterpipes I first run 1" utility grade poly and attach both ends. Then I push 1/2" pex (I use up all my heating loop scraps for this) through and then tape up the ends. Don't try it on sleeve much longer than about 20' - 25' as the friction gets bad enough at that length that you can't push that "string" any further.
Here's an example. Three lines - you can see two of them coming up in the background in the laundry - the other comes up at the toilet you can just barely see at the near right.
For water services I only sleeve going through concrete walls/footings and where it comes through the slab, again with utility grade poly-e.
I've seen pex survive being run through crushed stone gravel. It's tough stuff. I'd prefer to have some sand around mine though.
futz is offline   Reply With Quote
The Following User Says Thank You to futz For This Useful Post:
pauliplumber (05-30-2010)
Old 02-28-2010, 11:39 PM   #8
SummPlumb's Avatar
That looks good futz. If I sleeve pex, I use foam insuation or pvc thru a wall or under a footing. Us rebels in da South don't use radiant floor.
"The Plumbing Guru"
Old 03-03-2010, 12:56 AM   #9
AKdaplumba's Avatar
View AKdaplumba's Photo Album My Photos
seems to be common to use a piece of ABS for sleeving now.
AKdaplumba is offline   Reply With Quote
Old 03-03-2010, 08:54 AM   #10
Nipple Twister.
LEAD INGOT's Avatar
View LEAD INGOT's Photo Album My Photos
Check me if I'm wrong here Ron, but pex has the same OD as copper, not ID.
Scuse' me while I whip this out.
LEAD INGOT is offline   Reply With Quote
The Following 2 Users Say Thank You to LEAD INGOT For This Useful Post:
Protech (03-03-2010), rocksteady (03-05-2010)
Lawyer says "sink drain line is an outlet of a pipe" Avan General Plumbing Discussion 4 01-07-2010 05:27 PM
stuck 3" pipe and only 1 man 422 plumber Plumbing Pictures 32 01-04-2010 02:52 AM
My youngest in a 60" pipe 422 plumber Plumbing Pictures 12 04-14-2009 10:01 PM
Are People Generally "Good" or "Bad" DUNBAR PLUMBING Off Topic 5 04-01-2009 09:17 AM
Bathroom Sink/ Drain Pipe (Drain Pipe broke leading to ground) bli182nk General Plumbing Discussion 4 01-12-2009 10:36 AM
