Rheem gas heater making a banging noise - Plumbing Zone - Professional Plumbers Forum
Old 11-14-2012, 11:33 AM   #1
texplumber's Avatar
View texplumber's Photo Album My Photos
Default Rheem gas heater making a banging noise
Had a Rheem gas water heater that is making a banging noise when it heats up. Flushed out heater and removed baffle. It's still sounds like someone is hitting it with a bat when it heats up. Only a two year old heater.
texplumber is offline   Reply With Quote
Old 11-14-2012, 11:47 AM   #2
revenge's Avatar
View revenge's Photo Album My Photos
Check the anode rod
Behind every monsterous dog there is a monsterous human
revenge is offline   Reply With Quote
Old 11-14-2012, 12:19 PM   #3
texplumber's Avatar
Will have to do that next. Rheem is sending out a new burner assembly
Old 11-14-2012, 12:22 PM   #4
Do a water test for hardness. I have seen mineral build up so hard that flushing the tank did nothing.
The Following 5 Users Say Thank You to nhmaster3015 For This Useful Post:
Gettinit (11-14-2012), gusty60 (11-15-2012), plbgbiz (11-14-2012), Redwood (11-15-2012), rjbphd (11-14-2012)
Old 11-14-2012, 12:51 PM   #5
texplumber's Avatar
Tested water it was good.
Old 11-14-2012, 12:59 PM   #6
I Married Up
plbgbiz's Avatar
View plbgbiz's Photo Album My Photos
I think NH is on track. The only time I here banging in water heaters is when there is scale attached to the inside of the heater.
plbgbiz is offline   Reply With Quote
The Following User Says Thank You to plbgbiz For This Useful Post:
Old 11-14-2012, 01:01 PM   #7
texplumber's Avatar
I don't know I've heard them before but this is loud. Sounds like Someone is hitting the tank with a bat.
Old 11-14-2012, 01:20 PM   #8
UN1TED-WE-PLUMB's Avatar
View UN1TED-WE-PLUMB's Photo Album My Photos
Usually scale build up will sound more like rocks rumbling around inside the tank. Is your noise more of a one time hit or more of a rumble?
I don't see how a new burner assy will fix the problem.
Maybe drain the tank, remove drain valve and try to look in the bottom of the tank with a mini seesnake.. I've had to do that before in a similar situation.
UN1TED-WE-PLUMB is offline   Reply With Quote
Old 11-14-2012, 01:25 PM   #9
texplumber's Avatar
It's more of hitting sound that happens every couple of seconds.
Old 11-14-2012, 01:35 PM   #10
Just taking a shot in the dark here but maybe an extreme case of thermal expansion... Is there an expansion tank installed?
We get tons of calls this time of year for this. Everyone thinks they have a leak in a wall when it's just the plumbing system making noise as it heats and cools.
The Following User Says Thank You to UN1TED-WE-PLUMB For This Useful Post:
johnlewismcleod (11-15-2012)
GE nat gas water heater (same as Rheem) MikeS Residential Plumbing 26 06-10-2012 12:38 AM
Rheem---GE water heater Master Mark General Plumbing Discussion 40 02-20-2012 10:14 PM
PRV making all kinds of noise?? drsplumbing Residential Plumbing 7 11-02-2010 06:01 AM
Noise in water heater aadams Introductions 10 10-12-2010 07:53 PM
Making a Water Heater Replacement fun for the kids DUNBAR PLUMBING General Plumbing Discussion 3 08-05-2009 11:23 AM
