Came up and made an 'air scoop' nipple for a existing boiler repiping job that had air problem in the system. Resaon for the problem? They had a forced air company doing the boiler job.
Unless your going for a patent, a photo or drawing would be nice ...
Bill Parr LMP www.parrsplumbing.com click on ... A little of this and a little of that |
| The Following User Says Thank You to PLUMBER_BILL For This Useful Post: | Airgap (01-27-2012) |
Anything that slows the velocity of the water usually works .
The idea is to get the water flowing below 1 foot per second so that the air comes out of solution. Having it on the supply helps too since hotter water holds less oxygen. Outside of the internal baffle inside an air scoop of the screen/mesh inside of the microbubble air seperators, a large diameter pipe section with an automatic air vent will actually vent air from the system. |
Right on to the point, Trick 1, I made this with a 1 1/4 nipple going inside boiler on the side, crude but its better than nothing in this limited space room for 3 zones system that was 'destroyed' by forced air heating company.
SharkBite Certified
So let me get this straight
You were called out to a hacked up job and hacked it up further Sent from my portable office....yes I am at work |
Why couldn't you have just put a real air scoop in?
CT Unlimited Plumbing Contractor/ CT Unlimited Well Drilling Contractor/ CT Licensed Water Systems Operator/ NATE Certified HVAC Installer |
#8 | |
![]() sent from the jobsite porta-potty
''i would rather die on my knees with freedom then on my feet with no freedom" |
I have several air scoops laying around and reason for not using them are... don't have enough length and room in this tight qaurter to make it work.. keeping the cost down without repiping the existing manifold. Will let ya guys know how its work when done.
SharkBite Certified
That is the same excuse the first company used
| The Following 2 Users Say Thank You to OldSchool For This Useful Post: | ChrisConnor (01-28-2012), DesertOkie (01-28-2012) |
