Ok I need some help from some of u commercial service guys. I got a call about four months ago for a clogged soda machine drain in a subway. Went cleaned it, but it still drained slow, went below into the parking garage removed a section of pipe and removed a whole lot of sludge from the ninety that turns the drain horizontal. I was told by the building super that this happens every three or four months. ( the subway was new when I went). Got a call tonight that it's clogged again? Can there be something with this soda machine causing this build up. The drain is installed right. And its 2 inch from the wall to the main stack. Anyone ever had anything like this? Every three or four months screams something not right but I'm too new with sofa machines. What gives?
I've seen soda drains piped into a small grease trap like device to catch the slime... Even one was just a 5 gallon bucket with a water heater pan connector on the side about 6 in from top then out of it was piped into a hub drain with a air gap ... The bucket had to be emptied of the slime. I bet they just put it in the mop sink !!!!
I've run hot water lines to the soda fountain drains at quite a few places...
The ones that use them often do have less drain problems...
The first one I did was at a Subway...:laughing:
I ran a hose from the water heater to use while I was snaking the line and he asked if it would help to have a hot faucet right there and run hot water every night...
I told him it probably would and I ran a line over for him...
As I sit here sipping my morning coffee looking at Titan's picture of Coke snot, I am thinking that it looks like an intestinal parasite of some sort that was coughed up from the lung of a farm animal.....
Edit: I reread the posts, it seems like an enzyme injection system would be key, and considering the temp of the liquids draining out of the drippings tray and if the condensate drain off the ice machine also drains into that same drain then the snot is just being further solidified by the cool condensate and run off from the drippings tray, hot water would be key but an automated system would need to be installed to ensure the system is cleaned regulary.
NICE! this is a new concept to me. Makes sense, but i didn't know it'd do that. I do now.
I'll put that in my drain cleaner's book of knowledge
20.3K members
