Drain Cleaning Specialist
Roots can grow into PVC with Fernco's seen them grow into SDR 35 Gasketed Sewer Fittings also.
Charging less does not mean more call volume it just means you have to work harder to reach your goals. |
Illinois Licensed Plumber
Roots will grow in any pipe with a joint. That includes PVC that has been glued, cast iron with oakum and lead.
Ron Hasil Lic #058-160417 A-Archer Sewer & Plumbing specializing in: Tankless Water Heaters | Drain and Sewer Cleaning Sump and Ejector Pumps | Backflow RPZ Testing |
I am subcontracted by some plumbers to power rod drains for them. So I used to rod this line every two years and remove roots in two spots in a 100' clay sewer. This plumber talked the home owner in replacing the sewer with PVC, they put in glued joints. All seemed well for about 5 years, the 6th year the sewr was clogged. The roots where worse in the PVC joints then they where in the clay.
I have hours on hours of footage showing roots coming in through perfectly good joints in PVC on VHS tapes.
| The Following 2 Users Say Thank You to SewerRatz For This Useful Post: | ap plumbing (12-28-2010), UnclogNH (08-28-2010) |
I tell you one thing the LT1000 is a great tool, no more hours of footage to bore people with, just snap shots of the problem and e-mailed reports.
| The Following User Says Thank You to SewerRatz For This Useful Post: | AssTyme (08-28-2010) |
I don't buy it. The only time I've ever seen roots growing into pvc is when the joints were not made up or the pipe was so close to a massive tree that the roots expanded into it and cracked it. PVC ,when installed correctly, is hermetically sealed and cannot be penetrated by roots.
Period. I dare you to prove otherwise. ![]() Edit: I was refering to cemented joints only.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Drain Cleaner, Pipe Leak, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber, Haines City Plumber, Bartow Plumber Last edited by Protech; 08-28-2010 at 12:46 AM.. |
#10 | |
When I first started in the drain cleaning business I thought the same, that glued joints, since a glued joint is a chemical weld. But my father corrected me in my ways of thinking. He told me if the joint is 100% perfect the roots should not get in the joint. But most joints are not 100% perfect, all it takes is a small air pocket in the joint, the roots start of finner than human hair and find their way into the joint nursing off the water and growing which in turn opens the joint up more allowing more roots in and so on.
| The Following User Says Thank You to SewerRatz For This Useful Post: | UnclogNH (08-28-2010) |
| See what tree roots can do! | Bill | Residential Plumbing | 8 | 08-09-2010 01:11 AM |
| I smell like Sewer Roots! | DUNBAR PLUMBING | General Plumbing Discussion | 9 | 10-01-2009 01:31 AM |
| Got Roots? | UnclogNH | Drain and Sewer Cleaning | 8 | 08-14-2009 03:32 AM |
| roots removal | ROTOR KING | Drain and Sewer Cleaning | 20 | 01-01-2009 12:45 AM |
| Roots | jtp | Drain and Sewer Cleaning | 7 | 10-25-2008 11:14 AM |
