removing scratches caused by augers - Plumbing Zone - Professional Plumbers Forum
Old 03-13-2011, 10:38 PM   #1
Plantificus's Avatar
View Plantificus's Photo Album My Photos
Default removing scratches caused by augers
When scratches happen on the inside of a toilet from my auger or anything else, I suck the water out and use a product called "bar keepers friend" to buff out the scratches with minimal effort. it even works when the customer scratches it up with a coat hanger! (if they caused the scratch, I charge to remove it
just wanted to let everyone know what I found to work.. what do you guys use in that situation?
Plantificus is offline   Reply With Quote
The Following 4 Users Say Thank You to Plantificus For This Useful Post:
AssTyme (03-13-2011), plumbpro (03-14-2011), Tommy plumber (03-27-2011), xyleman (03-14-2011)
Old 03-13-2011, 11:01 PM   #2
I don't make them to start with...
Toothpaste will work too....
~Mark Twain~
Old 03-13-2011, 11:06 PM   #3
Will's Avatar
View Will's Photo Album My Photos
Just tell them you may scratch the toilet when you auger it and ask if it is something they still want you to auger. If they say go ahead knowing that you may scratch the toilet, there won't be a problem when you do.
Will is offline   Reply With Quote
Old 03-13-2011, 11:08 PM   #4
View PlumberDave's Photo Album My Photos
worn sand cloth works well but replacing the auger when or better before the rubber on the front gets worn works a lot better.
PlumberDave is offline   Reply With Quote
The Following 5 Users Say Thank You to PlumberDave For This Useful Post:
AssTyme (03-13-2011), JERRYMAC (03-26-2011), Redwood (03-13-2011), rocksteady (03-14-2011), Tommy plumber (03-27-2011)
Old 03-13-2011, 11:15 PM   #5
AssTyme's Avatar
View AssTyme's Photo Album My Photos
Just make sure that the rubber is correctly positioned, don't auger like a wild man and the bowl won't get damaged
AssTyme is offline   Reply With Quote
The Following 5 Users Say Thank You to AssTyme For This Useful Post:
JERRYMAC (03-26-2011), Redwood (03-13-2011), rocksteady (03-14-2011), Tommy plumber (03-27-2011), UnclogNH (03-14-2011)
Old 03-14-2011, 01:05 AM   #6
View ckoch407's Photo Album My Photos
Pumice stick. And of course, as stated by others, it's best not to leave a scratch. General makes a rubber pad that goes in the bowl to help prevent this for those who cannot figure out how to use the rubber at the end of the auger.
ckoch407 is offline   Reply With Quote
Old 03-14-2011, 07:57 AM   #7
I use a general auger with a rubber sleeve that is in good condition, the only time that I leave a scratch is when I run into the toilets that need to be augered backwards... or if I use the closet attachment for the water ram, there is a steel nut on the wrong side of the rubber cone
Old 03-14-2011, 09:31 AM   #8
www.DunbarPlumbing.com
DUNBAR PLUMBING's Avatar
I've scratched a few up in my day. It's hard to not see the closet auger push back, allowing the cable to hit the visible part of the trap when the toilet is full of human waste.
Keeping that rubber clean is important as well, as dirt from the bed of your truck, grease can be visible but removable... then lead to a complaint.
I've scratched up older ones but newer ones... I can recall one that I felt bad about.
Quit putting everything you shouldn't down the toilet and there's no need for a closet auger.
The Following 3 Users Say Thank You to DUNBAR PLUMBING For This Useful Post:
AssTyme (03-14-2011), JERRYMAC (03-26-2011), Mpls Jay (03-15-2011)
Old 03-14-2011, 11:35 AM   #9
View sewerman's Photo Album My Photos
Unhappy w/c scratches
greetings,
i have used the green scotch pads got that idea years ago at a supply house after opening more than one w/c box and finding scratches they pulled out with a few rubs, got to get the h2o out first.
marc
the sewerman
http://www.thesewerman.com
sewerman is offline   Reply With Quote
Old 03-14-2011, 05:59 PM   #10
gitnerdun's Avatar
View gitnerdun's Photo Album My Photos
Bar Keepers Friend has oxcalic acid in it. It works great on metal scratches and rust. It won't scratch like Comet. It's cheap. If you haven't used it, get some.
gitnerdun is offline   Reply With Quote
The Following User Says Thank You to gitnerdun For This Useful Post:
Urinal Augers A Good Plumber Drain and Sewer Cleaning 43 09-05-2011 11:37 AM
Removing this tub drain AKdaplumba Residential Plumbing 19 02-21-2011 06:50 PM
removing water heaters from attics TheMaster Residential Plumbing 17 11-12-2009 06:39 PM
accidents caused by negligence $$ NYCPlumber General Plumbing Discussion 10 09-16-2009 06:46 AM
