Got called out to a large Bar & Grill yesterday. No grease trap & a 160' run of 4" cast. Line was full of soft/tar like grease. Rodded through it 3 times with a doulble bladed 3" grease cutter and twice using a large spring retriever with my Spartan 300 with .55 cable. The first time I brought back about 20 mice. This line wasn't opening. Hooked up a flush bag and line opened right up. I then rodded through it two more times running a lot of water.
What would be the preferred blades and technique to properly open this gummy line using a drum machine ? |
AAAAAAAAHHHHH!!!
I probably would have done the same thing with one exception, we have a smaller jetter, and it definitely would have come into play.
Illinois Licensed Plumber
Augers work well in helping to stir up the grease. There are times I find duct taping a rag to the 3" cutter where you have two tufts of the rag sticking out each end that exceeds the diamtor of the pipe by an inch or so. This scours the pipe and helps push the blockage.
If the above does not work I fire up my small electric jetter.
Ron Hasil Lic #058-160417 A-Archer Sewer & Plumbing specializing in: Tankless Water Heaters | Drain and Sewer Cleaning Sump and Ejector Pumps | Backflow RPZ Testing |
| The Following 6 Users Say Thank You to SewerRatz For This Useful Post: | affordabledrain (07-19-2010), AssTyme (07-18-2010), Cuda (07-19-2010), RealLivePlumber (07-18-2010), retired rooter (07-20-2010), Tommy plumber (07-18-2010) |
#4 | |
| The Following 3 Users Say Thank You to TheMaster For This Useful Post: |
jA-Rod dat u?
Using the rag to punch a hole through is a good way but with a line in that condition I would have upsold to jetting for piece of mind....
"Fascism should rightly be called Corporatism, as it is the merger of corporate and government power." ~Benito Mussolini~ Lloyd Blankfein for President 2012 - Save Money Cut Out The Middleman!
| The Following User Says Thank You to Redwood For This Useful Post: | Cuda (07-19-2010) |
If you can find the $, a High pressure jet machine (jet rodder) will do the job. Been jet rodding one of the worlds biggest food outlets in Australia for about 15 years. And the grease in beyond grease to when I hardens and turn solid. And my 5000psi jet rod with a product call grease release cleans the drains right back.
On a big grease blockage i find the Rigid 1500 useless. The grease just build up behind the cable and does nothing but stir the grease into soup. With the jet rodder in and out in most cases 1/2hour Last edited by Aussieplumber; 08-12-2010 at 07:14 AM.. |
#7 | |
LICENSE PLUMBER
http://www.allanjcoleman.com/stoneage/nozzles.html My Plumbing Master back in the day was Mike and Carol Brady |
| The Following User Says Thank You to 130 PLUMBER For This Useful Post: | SewerRatz (08-12-2010) |
Drain Cleaning Specialist
When running into heavy grease or sludge I run a pair of paddle blades to stir it up good. When I find the grease or sludge clog is to heavy to be moved by the amount of water in the sewer. I run my blade past the clog stuff in a flush bag in with the cable turn it on and use the machines power feeder to pull the cable back while using the blade to chew up grease and water pressure to force the grease and sludge out of the line.
Works every time when you can't use a jet. ![]()
Charging less does not mean more call volume it just means you have to work harder to reach your goals. |
#9 | |
The flush bag seals with the cable in line ? This sounds like it would be a bit harsh on an expensive canvas flush bag ? |
My father used to tape a garden hose to a flat push rod. As you are pushing in the rod with the hose running it will back up once you pass the soft blockage it will stop backing up, so now you will know where to work the stoppage with the ball and end of the hose.
Now do not go out and buy a hand rod if you never used one. You can get yourself into tons of trouble if you do not use it right. I have seen more blown out elbows due to someone with a pushrod not knowing the difference between an elbow and a blockage.
| The Following User Says Thank You to SewerRatz For This Useful Post: | UnclogNH (08-12-2010) |
| grease trap | clarkplumber562 | General Plumbing Discussion | 30 | 05-24-2010 04:04 PM |
| Speaking of Grease. | ChrisConnor | Plumbing Tools and Equipment | 3 | 01-24-2010 01:35 AM |
| Grease | Cal | Plumbing Material and Products | 9 | 01-23-2010 11:28 PM |
| soft flux for winter | brass plumbing | Plumbing Material and Products | 9 | 12-19-2009 08:31 PM |
| Grease Traps | Plumbus | General Plumbing Discussion | 1 | 08-25-2008 08:11 PM |
