PEX fittings - Plumbing Zone - Professional Plumbers Forum
Old 02-28-2010, 01:56 PM   #1
Madame Moderator
Phat Cat's Avatar
View Phat Cat's Photo Album My Photos
Default PEX fittings
What's your opinion on the stainless steel PEX fittings vs. brass vs. plastic?
We have used brass exclusively and have not had any problems with reliability. Our one supplier was really pushing the plastic fittings, but too similar to the old poly set-up for us.
Other than lead content, is there another compelling reason to use stainless steel fittings rather than brass?
The Best Is Yet to Come . . .
Phat Cat is offline   Reply With Quote
Old 02-28-2010, 02:09 PM   #2
Ron
Banned
Ron's Avatar
I have not used them yet but had a supply rep stop by our work and give a demo on the plastic ones, there tough, you can take a hammer to them and they won't break or crack.
Old 02-28-2010, 03:16 PM   #3
futz's Avatar
View futz's Photo Album My Photos
Ya, well... They're going to have a tough sell. Lots of people have long memories and remember flooded houses from failing acetal fittings from the early days of poly-b. Now I'm pretty leery of plastic fittings.
I used some Philmac plastic water service fittings when they were still being sold - had no failures - but was always nervous about them. Now my supplier is stocking some black plastic corporation fittings (I forget the brand), the design of which makes me a LOT more nervous than Philmac. Screw that. I only use brass corporation fittings now. An "expensive" fitting is much preferable to a blowoff or other failure.
Brass fittings only for pex for me. I've never seen stainless ones. Brass has been 100% trouble-free since pex was brand new.
futz is offline   Reply With Quote
The Following User Says Thank You to futz For This Useful Post:
Protech (02-28-2010)
Old 02-28-2010, 05:44 PM   #4
View KCplumber's Photo Album My Photos
Rep told us plastic pipe, plastic fittings - been using them over a year
no problem so far- knock on wood. The new stainless veiga system looks like a hydralic fitting which is kool , but quite spendy
compared to plastic
KCplumber is offline   Reply With Quote
Old 02-28-2010, 05:51 PM   #5
Madame Moderator
Phat Cat's Avatar
I was more interested in learning about the stainless steel fittings rather than the plastic.
Old 02-28-2010, 06:00 PM   #6
Protech's Avatar
The only downside to stainless steel is the insane cost. If cost was no obstacle, then I would only install stainless steel pipe and fittings.
The downside to the polysulphone (the black plastic) fittings is that the ID of the fittings is smaller than the metal ones. Metal pex fittings already have a reduced diameter over copper and cpvc and going to the PS fittings is an even greater reduction. I tried the plastic fittings and if you do an entire house in them your pressure drop is insane unless you up size your lines. The other thing is that even though PS fittings seam to hold up ok (SO FAR!) I like Futz am very leary of plastic fittings. You will have a tough time selling to anyone who has any past experience with the polybutylene pipe/acetal fitting fiasco. They will most likely slam the door in you face when they see those plastic fittings. They are also susceptible to chemical attack like cpvc (though not to as great of an extent from what I read).
Brass is tried and true (unless you like in Nevada) and so is SS. I use brass and have for more than a decade with no problems what so ever. The jury is still out on plastic.
P.S. If you do decide yo go with plastic fittings then you may want to use a cold expansion system instead of a crimp system so that the flow-pressure losses will be minimal. Maybe uponor.....
Old 02-28-2010, 06:01 PM   #7
Protech's Avatar
4 times the price of brass but will outlast all of us. That's all ya need ta know.
The Following 3 Users Say Thank You to Protech For This Useful Post:
pauliplumber (02-28-2010), Phat Cat (02-28-2010), Redwood (02-28-2010)
Old 02-28-2010, 06:40 PM   #8
Madame Moderator
Phat Cat's Avatar
Thanx Protech! No desire to 'try' the plastic. Like you said, brass is tried and true. As for the s.s. fittings, four times the price explains it all.
Old 02-28-2010, 08:23 PM   #9
I know a guy who can have all the stainless pex fittings you want and you can even send a product for them to copy and then change alittle for it to be legal in the U.S. The manufacturer is in Korea. You can have them made to any specs you want. To get the listed its expensive.
Old 02-28-2010, 10:54 PM   #10
Protech's Avatar
What sort of quantities would these fittings need to be turned out at?
I would think each type of fitting would need to be produced in lots of 10,000 to make it worth while. So we are talking about over 1 million fittings for a full inventory. That's allot of coin for one company to shoulder. I have a tough enough time up-selling people on pex from cpvc. Adding the cost of SS fittings would price me right out of the market for 90% of my clientele. Also, since brass fittings have been shown to last more than 50 years in my area I have a tough time justifying the added costs.
Pex and Compression fittings bfriely Residential Plumbing 52 05-03-2012 10:23 PM
Sharkbite fittings TheMaster Off Topic (Non Trade) 50 05-18-2010 10:00 PM
ProPress Fittings user823 Plumbing Tools and Equipment 13 09-14-2009 08:46 PM
Pvc fittings TheMaster Plumbing Pictures 25 07-13-2009 01:04 PM
Nylon fittings Bill Plumbing Material and Products 6 08-10-2008 12:47 PM
