Leonard mixing valves? - Plumbing Zone - Professional Plumbers Forum
Old 07-20-2011, 09:03 PM   #1
Lead what?
View PeckPlumbing's Photo Album My Photos
Default Leonard mixing valves?
I just rebuilt a leonard 210 1/2" mixing valve for a sloan sensor operated bank. Anyone had to do this, if so are they very reliable? Went together fine. Old parts were pretty corroded and seized up. Its only 4 years old, seems crazy to be replacing a $200 spring already!
-Jerome Sweet
Peck Plumbing & Heating
Spokane, Washington
PeckPlumbing is offline   Reply With Quote
Old 07-20-2011, 09:19 PM   #2
plumb nutz's Avatar
View plumb nutz's Photo Album My Photos
They are meant to be serviced on a regular basis...
Though depending on water conditions I have seen lots of build up on the coils or coils flaking...
Temperamental but okay when the kinks are worked out...
plumb nutz is offline   Reply With Quote
The Following User Says Thank You to plumb nutz For This Useful Post:
PeckPlumbing (07-20-2011)
Old 07-22-2011, 09:33 PM   #3
PlungerJockey's Avatar
View PlungerJockey's Photo Album My Photos
I pulled a Leonard TM-20 out of a house the other day. Supply house quoted 438 for a rebuild kit and 478.00 for a new valve. I replaced it with a small and inexpensive Honeywell for 88.00
Don't get me wrong, I love Leonard mixing valves, but it is overkill for this unit. It's a duplex and has a AO Smith high recovery 50 gal that supplies water for domestic and heating uses. When the units where built, the plumber connected the Leonard at the top of the waterheater. He placed tees at the water heater nipples and came out to the mv. The only problem was they used galvanized tee's and nipples . The tempering valves are getting clogged and trashed up.
I've been cleaning them out as the hot water pressure drops in the units. From now on I'm replacing the Leonards and re-piping the water heaters.
PlungerJockey is offline   Reply With Quote
Old 10-03-2011, 10:46 AM   #4
Mr Bruno
Mr Bruno's Avatar
View Mr Bruno's Photo Album My Photos
I have had the same issues with Leonard mixing valves. They seize up, and you end up breaking the spring. Easy to rebuild, but like PlungerJockey stated, the complete rebuild is almost as much as the new valve. I haven't used the Honeywell model, but will be looking into it now.
Mr Bruno is offline   Reply With Quote
Gate valves, globe valves or ball valves for residential potable water. Protech Plumbing Material and Products 51 08-25-2011 08:39 PM
Beware of Honeywell Mixing Valves WaterHeaterShop Plumbing Material and Products 14 06-19-2011 08:49 AM
Thermostatic Mixing Valves OldSchool Plumbing Code 40 08-24-2010 09:48 PM
Mixing Valves belu0501 Plumbers Swap 4 08-04-2010 08:44 AM
do all thermostatic mixing valves lag. justin General Plumbing Discussion 29 07-21-2010 07:44 AM
