Leaky sharkbite - Plumbing Zone - Professional Plumbers Forum
Old 04-11-2012, 04:02 AM   #1
View rzp 06's Photo Album My Photos
Default Leaky sharkbite
found my first leaking sharkbite the other day. It was a 1/2" coupling adapting copper to pex on a hot water line. The copper side was fine but the teeth in the sharkbite cut grooves in the outside wall of the pex allowing it to slide out and leak. I could tell from the grooves in the pex that it had been pushed in all the way and it did have the pex insert in it. The pex was straight and not under any strain. Must have been expansion/contraction the caused it to pull out.
ho said it was done about 2 years ago.. anyone else seen this happen?
it was Bow superpex
rzp 06 is offline   Reply With Quote
Old 04-11-2012, 08:06 AM   #2
I Married Up
plbgbiz's Avatar
View plbgbiz's Photo Album My Photos
I have seen them leak on copper after about 6 months.
The self-made man is just a boy that won't say who helped him.
Thanks Dad.
plbgbiz is offline   Reply With Quote
The Following User Says Thank You to plbgbiz For This Useful Post:
Protech (04-12-2012)
Old 04-11-2012, 08:40 AM   #3
hero
damnplumber's Avatar
View damnplumber's Photo Album My Photos
If the pipe was not deburred or chamfered, it could have scorred the sharkbite causing it to leak. Ask me how I know?
damnplumber is offline   Reply With Quote
The Following User Says Thank You to damnplumber For This Useful Post:
Tommy plumber (04-11-2012)
Old 04-11-2012, 10:11 AM   #4
Will's Avatar
View Will's Photo Album My Photos
I don't mind the O-ring seal, probably last a long, long, long time. What bothers me about the sharkbite type of fittings is that nothing keeps them rotating and the expansion and contraction can't be good for them. Seems like it would prematurely wear out the O-Ring seal. Not sure why anyone would use sharkbite on PEX anyway, not like it's hard to hook up PEX as it is. Even in tight spots.
Will is offline   Reply With Quote
Old 04-11-2012, 10:52 AM   #5
View wookie's Photo Album My Photos
Have'nt seen them leak yet in the field but if theres going to be any movement of any type they will leak. Just have not run into them. Not a matter of IF but When they leak. Just like the very popular John Guest fittings. Fine when new but get some time on them and a little movement= leak.
I do use hackbites on temporary work.
wookie
wookie is offline   Reply With Quote
Old 04-11-2012, 10:59 AM   #6
Lego Expert
GREENPLUM's Avatar
View GREENPLUM's Photo Album My Photos
Originally Posted by Will View Post
I Not sure why anyone would use sharkbite on PEX anyway, not like it's hard to hook up PEX as it is. Even in tight spots.
PEX or Copper to CPVC,
that would be a reason to use hackbites
GREENPLUM is offline   Reply With Quote
Old 04-11-2012, 11:14 AM   #7
Plumba
Qball415's Avatar
View Qball415's Photo Album My Photos
If I did run into a situation where I ran into pex. I don't have an expander or crimping tools to do a pex repair and would either refer call out or worst case use a Sharkbite connector. I don't know another product to use as a transition.
Qball415 is offline   Reply With Quote
Old 04-11-2012, 11:49 AM   #8
View Widdershins's Photo Album My Photos
Considering how pretty much all brands of PEX can be crimped, it might be worth your while to pick up a crimper one of these days.
As for sharkbites -- I'll use them to transition from copper to pex in a crawlspace or for a temporary connection, but I would never bury one inside of a wall or ceiling.
Widdershins is offline   Reply With Quote
Old 04-11-2012, 12:46 PM   #9
Agreed. They have their place.
I'll use them sometimes after I remove a W/H. I'll cap the (2) 3/4" lines while I run to go get the replacement W/H.
Old 04-11-2012, 09:59 PM   #10
RealCraftsMan's Avatar
View RealCraftsMan's Photo Album My Photos
They will fail, please keep using them. In a few years I will make the big bucks fixing all the hack work!
No sir that's really the price and no I will not take any off.
RealCraftsMan is offline   Reply With Quote
The Following 2 Users Say Thank You to RealCraftsMan For This Useful Post:
bizzybeeplumbin (04-12-2012), Protech (04-12-2012)
SharkBite DUNBAR PLUMBING General Plumbing Discussion 65 03-29-2012 12:32 AM
Leaky Wiki ckoch407 Off Topic (Non Trade) 17 09-03-2011 08:41 AM
Caulking around leaky kitchen sink? della1 General Plumbing Discussion 3 06-24-2011 08:32 AM
Leaky shower valve Scott V General Plumbing Discussion 2 06-16-2009 10:13 AM
Leaky WH Airgap Plumbing Pictures 37 05-06-2009 03:25 AM
