Old 10-09-2009, 04:01 PM   #1
HI
house plumber's Avatar
View house plumber's Photo Album My Photos
Send a message via Yahoo to house plumber
Default New Kohler toilet
I installed the Presuade today and what a POS. You have to drill 2 - 3/8 holes for the 2 mounting brackets then set them. They give you a cut sheet. If your flange is any less than 12 inches to center, it wont work. So you have to build the toilet first and you have to use a braided supply. One comes with but it's on a 12" so I had to go get a 20". The tank is so small I could barely get my hands in there to tighten the tank bolts between the flush valve and fill valve. When you put the wax ring down you use NO closet bolts. So when you're setting it down to set it, if you're by yourself you have to guess where the flange is at. You only secure it with the side mounting brackets. It's kinda similar to a gerberit. I would not recommend buying this tolet or setting it on wood floors or the second floor. And I feel sorry for the service plumber that will have to go replace stuff on it. The hole in the last pic is where the supply comes out and they give you a plastic trim piece that fits in there to cover it up.
http://www.us.kohler.com/onlinecatal.../1087557_1.pdf
house plumber is offline   Reply With Quote
Old 10-09-2009, 04:51 PM   #2
Plumbing Contractor
ESPinc's Avatar
View ESPinc's Photo Album My Photos
Yea, what used to take 20 minutes now takes 3 hours, I'd like to see the engineer of this pos come set one. they would be off the market faster than they came on...
BTW to service this great POS, you will either have to shut the house down or pull this piece of crap... yea, seen it once, it was enough for me!!!!
ESPinc is offline   Reply With Quote
Old 10-09-2009, 05:00 PM   #3
HI
what sucks about it is if you dont get those mounting brackets right then you have to keep pulling it and adjusting them. Then what you bolt the toilet to are these nuts that a c- clipped in that move up and down. So if you shim the toilet the mounting hole is higher than the nut. Then you have to try and get the bolt in the nut which takes another 45 minutes. I agree, the designer wouldn't know how to set it out on a job. It's easy to do when you're at the factory with no wall behind it.
The Following User Says Thank You to house plumber For This Useful Post:
ESPinc (10-09-2009)
Old 10-09-2009, 05:03 PM   #4
View Herk's Photo Album My Photos
Aw, don't worry: if you don't like it, Kohler will make something completely different next year.
Herk is offline   Reply With Quote
The Following 7 Users Say Thank You to Herk For This Useful Post:
Colgar (10-09-2009), Nevada Plumber (10-09-2009), pauliplumber (10-09-2009), Pipedoc (10-10-2009), Redwood (10-14-2009), SlickRick (10-09-2009), TheMaster (10-09-2009)
Old 10-09-2009, 05:08 PM   #5
View Colgar's Photo Album My Photos
I did one of those in the silly extreme home makeover house that got done here last year.
I wasn't overly impressed, either.
Colgar is offline   Reply With Quote
Old 10-09-2009, 05:57 PM   #6
Senior Moment
pauliplumber's Avatar
View pauliplumber's Photo Album My Photos
Did the tank to bowl bolts come with metal washers for the inside of the tank?
pauliplumber is offline   Reply With Quote
Old 10-09-2009, 06:01 PM   #7
I'd refuse to install it and walk off. Enough of that would happen then kohler would wise up. I hate kohler products for the most part. Herk nailed it....so true herk.
Old 10-09-2009, 06:07 PM   #8
HI
No it had rubber washers.
Old 10-09-2009, 06:18 PM   #9
Senior Moment
Interesting. I never use metal washers on the inside of the tank, I just figured metal on metal in that application would not be a good seal. However, I have seen on tank repair bolts package it shows the metal on the inside, always figured it was wrong, so maybe I'm the one that's wrong?
Old 10-09-2009, 09:29 PM   #10
Plumber Jim's Avatar
View Plumber Jim's Photo Album My Photos
I agree with pauli. I never put metal washers on the inside of the bowl like that. they rust if they don't leak first.
Plumber Jim is offline   Reply With Quote
The Following User Says Thank You to Plumber Jim For This Useful Post:
Kohler sucks Bill Plumbing Material and Products 44 11-28-2011 08:22 PM
Kohler DTV shower. ROCKSTARPLUMBER Residential Plumbing 36 12-28-2009 09:51 PM
problem with Kohler toilet Plasticman Residential Plumbing 19 12-27-2009 10:04 PM
Kohler sink Bill General Plumbing Discussion 18 09-03-2009 02:24 PM
Kohler Escale rbsremodeling Plumbing Material and Products 3 03-09-2009 12:26 AM
