fleck 2900 - Plumbing Zone - Professional Plumbers Forum
Old 01-16-2011, 06:04 PM   #1
View 1703's Photo Album My Photos
Default fleck 2900
Rebuilt one of these last week, took a few pics.
The animal in question
With the controls off and lower piston out
Top piston, seals and spacers out, ready to go back in. I'll explain my use of the rag in a bit
The upper and lower pistons, upper and lower seal and spacer stacks
These are the "stuffer" tools used to "stuff" the seals and spacers into the head.
The seals go on the inside like this
You the shove the tool into the head until it bottoms out, push the middle of the tool in while pulling the tool out, setting the seal.
The spacers go in on the other end of the tool:
Push it in until it bottoms out then pull back on the middle of the tool leaving the spacer in place.
Here is the top one in the head. I put the pen marks on the tool to help me know if I'm in bottomed out.
The rag- The first time I ever did one of these, I was told no special tools were needed. Some people make their own tools to install the seals and spacers. I'm not good enough to do that. The upper piston is a booger. If you don't have the seals set where they belong, they can fall down through the head into the mineral, never to be heard from again. I stuff the rag into the lower piston hole so if I don't have a seal set right it will fall into the rag and I can dig it out. When I do the lower seals and spacers, I take a piece of solder and immediately stick it through the hole when I pull the tool out in case one tries to pop out when I'm not looking.
1703 is offline   Reply With Quote
The Following 6 Users Say Thank You to 1703 For This Useful Post:
6th Density (01-16-2011), piercekiltoff (01-17-2011), Proud Plumber (01-16-2011), rocksteady (01-17-2011), sheeptown44 (01-16-2011), SlickRick (01-16-2011)
Old 01-16-2011, 07:07 PM   #2
Canadian Red Seal Plumber
Lifer's Avatar
View Lifer's Photo Album My Photos
Send a message via MSN to Lifer
so do you often put tools you are using in someones water treatment system on the floor? I Bet you usually set them somewhere much cleaner and only put them there to take the picture AFTER you serviced this unit and are currently letting them soak in some sanitizer. And what you meant by rag was sterile cloth ..
Lol just bustin... thanks for the step by step.
Lifer...
Joby Reid
South Shore Regional School Board
Bridgewater N.S Canada
Lifer is offline   Reply With Quote
Old 01-16-2011, 09:15 PM   #3
gusty60's Avatar
View gusty60's Photo Album My Photos
Is the clevis hanger on the left just for looks? Just bustin...
gusty60 is offline   Reply With Quote
Old 01-17-2011, 07:07 AM   #4
Lifer...
So are you sayin I shouldn't keep those in the bucket with my plungers and closet augers?
Old 01-17-2011, 07:09 AM   #5
Apparently.
I saw it when I was putting the softener back together and thought I'd fix it when I was done. That's as close as I got to it, cuz I totally forgot about it..
Old 01-17-2011, 01:20 PM   #6
rocksteady's Avatar
I have a possbly dumb question for you.
Can you not use the piston as an "installation tool"? Sometimes when rebuilding other Fleck heads I'll stack the seals and spacers on the piston and install them all together. I've never rebuilt a 2900 so I don't know if this would work but it would keep anything from falling down.
Paul
Rocksteady Plumbing
(805) 237-7625 (ROCK)
The Following User Says Thank You to rocksteady For This Useful Post:
1703 (01-18-2011)
Old 01-18-2011, 07:07 AM   #7
Not a dumb question at all. I hadn't thought of it, but I bet it could be done. Have to keep them tightly bunched together and hope the end they don't come off the end.
If you have done that on other fleck's it would probably work on this one as they're all basically the same idea.
Old 01-18-2011, 08:06 AM   #8
Rebuilding fleck valve heads is why I greatly prefer Clack valve heads
The Following User Says Thank You to nhmaster3015 For This Useful Post:
Mississippiplum (02-07-2012)
Old 01-18-2011, 09:15 AM   #9
stillaround's Avatar
Is that because they dont need rebuiling or are much easier to rebuild...
Government does not solve problems; it subsidizes them.
Old 01-18-2011, 05:21 PM   #10
I hope you didn't forget your gardening hoe when you left. (4th picture)
