Water softener hooked up backwards - Plumbing Zone - Professional Plumbers Forum
Old 11-22-2011, 12:15 AM   #1
View luigi15's Photo Album My Photos
Default Water softener hooked up backwards
Anyone know what happens when you hook water sfotener up backwards?
One of my apprentices did this and I'm wondering if resin would end up in the waterlines because of this..
luigi15 is offline   Reply With Quote
Old 11-22-2011, 12:21 AM   #2
View TX MECH PLUMBER's Photo Album My Photos
Did he pipe the inlet to the out let and vise versa??? Heck I'd think you'd get hard water!!! As long as the drain is piped to the drain you should be fine!!!
TX MECH PLUMBER is offline   Reply With Quote
Old 11-22-2011, 12:25 AM   #3
revenge's Avatar
View revenge's Photo Album My Photos
I saw one piped back wards and the resign destroyed all the faucet carts and the fill valves
revenge is offline   Reply With Quote
The Following 5 Users Say Thank You to revenge For This Useful Post:
Epox (11-22-2011), goob (11-22-2011), Redwood (11-22-2011), Richard Hilliard (11-22-2011), SHEPLMBR70 (04-28-2016)
Old 11-22-2011, 12:30 AM   #4
O chit!!!! Why did you do that revenge?? Lol
Old 11-22-2011, 12:47 AM   #5
revenge's Avatar
It was origanly a call, on low water pressure. After i pulled out a few aerotors i started getting pitchers full of sand. So i called my boss and he told me to ask about water softner. They had hired a local water treatment co. to install a few months back. So i checked and it was installed backwards. The carts on the shower delta had to replace all delta faucets in house needed new carts the filter on fridge and or had to replace. And all of the fill valves huge ass ticket
The Following User Says Thank You to revenge For This Useful Post:
Old 11-22-2011, 01:02 AM   #6
rocksteady's Avatar
Yes, a water softener piped backwards will blow resin throughout the house. The head is desigend as either an up-flow or down-flow so feeding it backwards is BAD. Get back over there and but the unit on bypass. If the water pressure isn't too high, you might be o.k. but you need to correct it asap.
Paul
Rocksteady Plumbing
(805) 237-7625 (ROCK)
The Following 2 Users Say Thank You to rocksteady For This Useful Post:
Epox (11-22-2011), Redwood (11-22-2011)
Old 11-22-2011, 01:57 AM   #7
View Epox's Photo Album My Photos
It can take alot of flushing to get the resin flushed out of the piping too. Sometimes the softener piping at the wall is plumbed backwards and this causes alot of wrong connections. Not unusual for me to find this even with a valve on it. Best to verify which is the supply.
Epox is offline   Reply With Quote
The Following User Says Thank You to Epox For This Useful Post:
rocksteady (11-22-2011)
Old 11-22-2011, 02:04 AM   #8
rocksteady's Avatar
That is the first thing I do when installing a softener, even if there's one already there. I'll cut the loop (or remove the old w/s) and then crack the service with a bucket under each pipe. After I see which one the water is coming out of, I solder on a ball valve. Then I turn the water on again to double check.
I once was installing a w/s and followed my normal routine. After I had the ball valve on I turned the water on and found water flowing out of the other line. So I soldered on a second valve and turned the water on again. Pressure at both valves! Somebody had plumbed the loop wrong; no 90's in the attic but rather tees. The house was fairly new so I left the h.o. to deal with the builder on that but I told them I couldn't install their w/s.
Paul
Rocksteady Plumbing
The Following User Says Thank You to rocksteady For This Useful Post:
Epox (11-22-2011)
Old 11-22-2011, 06:53 AM   #9
View Mississippiplum's Photo Album My Photos
Well you will have to repack the softener and. Plumbing a softener backwards forces resin beads out of the mineral tank and into the water supply. You might even have to clean resin beads from the head and fill/suction assem for the brine tank.
Mississippiplum is offline   Reply With Quote
Old 11-22-2011, 07:53 AM   #10
Journeyman
pigskin plumber's Avatar
View pigskin plumber's Photo Album My Photos
Don't water softeners have an inlet and outlet labelled?
pigskin plumber is offline   Reply With Quote
Water Softener to do this week! vinpadalino Residential Plumbing 24 09-15-2011 02:24 PM
Water Softener tungsten plumb General Plumbing Discussion 6 07-21-2010 04:51 PM
Pelican Water Technologies - Water Softener? rocksteady General Plumbing Discussion 2 03-05-2010 02:04 PM
Installing a Water Heater Hooked to a Drain Pipe DUNBAR PLUMBING General Plumbing Discussion 12 02-08-2010 01:40 AM
Water softener (NOT MY WORK) 3KP Plumbing Pictures 17 12-23-2009 03:25 AM
