Type "K" copper fittings - Plumbing Zone - Professional Plumbers Forum
Old 05-07-2009, 07:34 PM   #1
Protech's Avatar
Default Type "K" copper fittings
Nobody seems to make them. What's the point of installing K pipe if the fittings are type L?
Old 05-07-2009, 07:36 PM   #2
Illinois Licensed Plumber
SewerRatz's Avatar
I only install K copper underground in one full length from the B-box to the inside of the home. Once inside and above ground the requirement is back to Type L. So I never had the need for any fitting other than flare for underground work.
SewerRatz is online now   Reply With Quote
Old 05-07-2009, 07:39 PM   #3
All fittings are made from type M copper actually, they are actually heavier wall than M copper from the wrot extrusion process, but they are made out of M copper.
The Following 2 Users Say Thank You to user4 For This Useful Post:
gusty60 (05-07-2009), sparky (02-23-2015)
Old 05-07-2009, 07:52 PM   #4
Protech's Avatar
So you are saying that the actual wall thickness of the fittings are the same as the equivalent size K pipe or thicker in all water exposed parts of the fitting?
Old 05-07-2009, 09:48 PM   #5
SPH
SPH's Avatar
View SPH's Photo Album My Photos
I'm pricing a job now that is requiring all above slab water piping to be Type K. Not normal for this area.
SPH is offline   Reply With Quote
Old 05-07-2009, 09:59 PM   #6
Protech's Avatar
Again, why even bother with K copper if the fittings are thinner than the pipe? If anything I would want the fitting wall thickness a bit thicker than the pipe.
Almost every pinhole I ever repaired (hundreds) on hard copper was on the fitting not the pipe.
Soft copper is a different story.
Old 05-07-2009, 10:12 PM   #7
SewerRatz's Avatar
How about using cast brass fittings instead?
Old 05-08-2009, 12:48 AM   #8
View Scott K's Photo Album My Photos
The only reason I could see them wanting type K copper is for "longetivity." I did one job in Pitt Meadows SPH where they spec'd type K for the hot lines, and type L for the cold lines.
But if they want longetivity, they should spec Fusiotherm/Aquatherm Fusion Polypropolene. It does have a fire rating and it'll outlast Copper in a lot of applications.
Scott K is offline   Reply With Quote
Old 05-08-2009, 08:46 AM   #9
Protech's Avatar
I've got an owner/builder who want a house built with copper. I've explained that copper doesn't do well here but they still want it. If I've got to do it in copper I at least want it to be hard copper and as thick as I can get it.
I have considered brass fittings but then I’ve got to worry about turbulence, casting defects, and dezincification.
They good thing is that the system is going to be fed well water with little or no chlorination. In this area, copper water systems last 50-60 years on well water and 15-30 on city water. I’m just being ultra cautious as I make my living removing copper and putting in PEX and I now have a HO making me put copper in. I’m only going to give a 10 year warranty on the copper no matter what kind goes in so it’s not a liability thing; it’s a being able to sleep at night thing.
Old 05-08-2009, 12:06 PM   #10
Associated Plum's Avatar
View Associated Plum's Photo Album My Photos
Nibco's website states
Q: Copper tubing wall thickness is designated “K,” “L” or “M.” What
are the copper fittings applicable to?
A: Copper fittings’ wall thickness is determined by standards (ASME
B-16:22 and MSS-SP-104). These standards address minimum wall
thickness (per size) for the full range of copper fittings and are not
intended to match tubing wall thicknesses.
Associated Plum is offline   Reply With Quote
The Following 2 Users Say Thank You to Associated Plum For This Useful Post:
422 plumber (02-23-2011), Airgap (05-08-2009)
Are People Generally "Good" or "Bad" DUNBAR PLUMBING Off Topic (Non Trade) 5 04-01-2009 08:17 AM
"Go Green" water saver dishwasher user823 General Plumbing Discussion 6 03-12-2009 09:51 PM
How To "quote" a post On Video Wethead Site Help and Suggestions 3 12-30-2008 10:17 PM
3" L Copper ILPlumber Plumbers Swap 12 09-20-2008 09:55 PM
"Functioning of a drum, float, or water column" I'mYourTourGuide Plumbing Code 0 08-26-2008 08:31 PM
