Old 09-08-2008, 07:58 PM   #1
Bill's Avatar
Default Tie into cast iron
OK. I have to tie into a 3" x 2" cast iron fitting so I can run my PVC. I need to remove the 1-1/2" galvanized pipe which is completely cloged up that has been installed with oakum and lead then try to attatch a 2" PVC to the cast iron hub because I have a shower drain that must run into it.. I was thinking a fernco to do this though the supply houses say I cant because the fernco wont go over the outside the hub. My other option was to insert the 2" PVC into the hub and reset the oakum then pour lead around the PVC. I CAN NOT remove the cast iron without disturbing the downstairs walls which I really do not want to do.
Also what is the best way to install a PVC toilet flange into a cast iron fitting? I know they have those screw in type with the rubber gasket. I may use that with some duck grease on the rubber.
Any thoughts?
Virginia Plumbing Codes
Virginia Department of Licensing
Everything in the known universe is governed by "Cause and Effect", there is no getting around it. Think about what you do before you do it.
Old 09-08-2008, 08:05 PM   #2
Master Plumber
"DAPlumber" 101's Avatar
View "DAPlumber" 101's Photo Album My Photos
Originally Posted by USP45 View Post
OK. I have to tie into a 3" x 2" cast iron fitting so I can run my PVC. I need to remove the 1-1/2" galvanized pipe which is completely clogged up that has been installed with oakum and lead then try to attach a 2" PVC to the cast iron hub because I have a shower drain that must run into it.. I was thinking a fernco to do this though the supply houses say I cant because the fernco wont go over the outside the hub. My other option was to insert the 2" PVC into the hub and reset the oakum then pour lead around the PVC. I CAN NOT remove the cast iron without disturbing the downstairs walls which I really do not want to do.
Any thoughts?
Instead of putting a 2" piece of pvc into 2" hub and leading around it get a 2" galv nipple and then after it is leaded in use your fernco or clamp all. I have seen pvc leaded in but your taking a chance do to the extreme heat.
I suffer from I.D.G.A F. disorder.
"DAPlumber" 101 is offline   Reply With Quote
Old 09-08-2008, 08:11 PM   #3
View Killertoiletspider's Photo Album My Photos
Our code calls for the proper transition fitting, so I would use a 2" PVC hub adpt and pour a lead joint.
Those bolt in closet flanges are a code violation here, why not just install another CI flange?
Killertoiletspider is offline   Reply With Quote
Old 09-08-2008, 08:56 PM   #4
ILPlumber's Avatar
Agreed. One thousand percent.
Old 09-08-2008, 10:22 PM   #5
Ron
Ron's Avatar
Use a 2" seal tight, thats what I would use.
Old 09-08-2008, 10:28 PM   #6
ILPlumber's Avatar
I never had a heat issue caulking in PVC in a CI hub. They look quite nice when done. If it's in a house they might not like the smell though. I have had success with the seal tites
I wouldn't use a fernco on the outside of the hub. Big edge there to catch all kinds of stuff on. As well as not being code compliant here.
Old 09-08-2008, 10:37 PM   #7
Ron
Ron's Avatar
This is the fernco donut, I call them seal tights, fit into the hub of cast. Comes in many sizes.
Old 09-08-2008, 10:40 PM   #8
ILPlumber's Avatar
Yup. Those babies fit nice and tight. I usually have to put some gasketed pipe lube on the pvc to get it in. Chamfered end helps temendously.
Old 09-08-2008, 10:41 PM   #9
Ron
Ron's Avatar
Yep pipe dope is needed to persuade the pipe to bottom out in it.
Old 09-08-2008, 10:44 PM   #10
Code violation to use a gasket above ground in Chicago, IL would know state code better than I.
falling cast iron Bill Plumbing Safety 9 07-05-2010 07:12 PM
Gray Cast Plumberman Commercial Plumbing 14 01-06-2009 01:23 PM
First cast iron job Bill Residential Plumbing 48 12-21-2008 02:17 PM
Ductile Iron Plumberman Plumbing Pictures 4 08-10-2008 09:38 PM
