Securing outside faucets - Plumbing Zone - Professional Plumbers Forum
Old 04-28-2011, 01:22 PM   #1
View user2090's Photo Album My Photos
Default Securing outside faucets
I am wondering what you do to secure an outside faucet when there seems to be a lack of solid materials? With all the cheap construction out there, someone has to have a awesome solution to the problem. Its a wonder these houses don't blow down with no plywood sheathing.
I do sometimes slid a piece of plywood under the siding, if it is possible without creating a bulge. Have been considering sheet metal, but. Then there is always cutting siding, installing a j-block and then putting the faucet back on. But with the goal to keep prices and work comparable, I am looking for a better way.
user2090 is offline   Reply With Quote
Old 04-28-2011, 01:40 PM   #2
Will's Avatar
View Will's Photo Album My Photos
Drop eared 90????
Will Rogers Plumbing (405) 323-2852
Moore, Oklahoma
"We Unclog Drains That Others Can't!"
http://www.willrogersplumbing.com/
http://www.facebook.com/#!/pages/Will-Rogers-Plumbing/112198585505675
Will is offline   Reply With Quote
Old 04-28-2011, 01:52 PM   #3
plumb nutz's Avatar
View plumb nutz's Photo Album My Photos
If I'm working on an outside faucet, 9 times outta 10 I'm replacing it. I always work from the inside out so securing the faucet is no big deal.
If its flapping in the wind when I get there and the outside wall is that crappy fiberboard I can't help them if there is no access to it from the rear. If I can get to it I ether use a stout bracket to secure or a ring clamp up tight against the wall if that works better like with block
plumb nutz is offline   Reply With Quote
Old 04-28-2011, 02:23 PM   #4
I Like Tater Tots
Pipe Rat's Avatar
View Pipe Rat's Photo Album My Photos
I use silicone, duct tape and Mighty Putty. Awesome combination.
"The fitting in question is the one that is threaded onto the galvanized piping and looks like a peice of pipe with a bubble in it."
"Yes but in 1950 i bet the water pressure was lower than now so m copper could hold up."
Pipe Rat is offline   Reply With Quote
The Following User Says Thank You to Pipe Rat For This Useful Post:
easttexasplumb (04-28-2011)
Old 04-28-2011, 03:46 PM   #5
View Airgap's Photo Album My Photos
"Sillyduckputty" for short.....
AG..Keepin' the good water from the bad water....
Airgap is offline   Reply With Quote
The Following User Says Thank You to Airgap For This Useful Post:
Pipe Rat (04-28-2011)
Old 04-28-2011, 03:50 PM   #6
Will's Avatar
Try ball bearings...
Moore, Oklahoma
The Following 2 Users Say Thank You to Will For This Useful Post:
Airgap (04-29-2011), PeckPlumbing (04-30-2011)
Old 04-28-2011, 05:57 PM   #7
AKA house plumber
Optimus Primer's Avatar
View Optimus Primer's Photo Album My Photos
What, no foam o fill?
Optimus Primer is offline   Reply With Quote
Old 04-28-2011, 05:57 PM   #8
Plumber Jim's Avatar
View Plumber Jim's Photo Album My Photos
I the WB has a clamp you can attach to the pipe on the inside like for bonding an electrical ground then has 2 screws you tighten to pull it in. really depends on the job.
Plumber Jim is offline   Reply With Quote
Old 04-28-2011, 08:01 PM   #9
18" drywall screws and liquid nails.
The Following User Says Thank You to user4 For This Useful Post:
DUNBAR PLUMBING (04-28-2011)
Old 04-28-2011, 08:04 PM   #10
RealLivePlumber's Avatar
Ta Da.
http://www.hosebibbmountingplate.com/home.html
Use them quite a bit. They work great.
RealLivePlumber
You can make it happen, you can watch it happen, or you can wonder wtf happened.
Phil Harris 2009
RealLivePlumber is offline   Reply With Quote
The Following 4 Users Say Thank You to RealLivePlumber For This Useful Post:
422 plumber (04-28-2011), Pipe Dreams (04-28-2011), PlumberDave (04-29-2011), SlickRick (04-28-2011)
Methods for securing grab bars? user2090 Residential Plumbing 39 10-29-2010 05:21 AM
lav faucets cf?? beachplumber Plumbing Material and Products 4 02-10-2010 12:48 AM
What are the best faucets? hepco General Plumbing Discussion 32 12-20-2009 10:58 PM
Securing Pvc flanges slab TheMaster General Plumbing Discussion 26 08-11-2009 05:27 PM
What faucets? Song Dog Plumbing Material and Products 24 09-13-2008 11:10 PM
