Old 08-19-2009, 09:32 PM   #1
Master Plumber
lpayne1234's Avatar
View lpayne1234's Photo Album My Photos
Default question about Delta Scald Guard shower faucetts
I have a Delta shower faucett (scaldguard) that is for a handicap shower. At the college where I work ,The shower is operated by the handle on left side of tub/shower then the tub is operated by a individual handle also. My question, the shower has nothing but hot water I have changed th Delta cartridge and the 2 springs and boots. Still nothing but hot water, I have not fooled with many of these. the ones I have repaired replaced cartridge and everything was fine, just wanting some input.
Thanks
lpayne1234 is offline   Reply With Quote
Old 08-19-2009, 09:57 PM   #2
stillaround's Avatar
Doe the tub only have cold water????? I had to ask.........(I might need to physically pull myself away from the computer)
seriously..you need to check 1st that you have cold water to the fixture and rule that out.
Old 08-19-2009, 10:42 PM   #3
Master Plumber
lpayne1234's Avatar
seriously, Yes it does have cold water supplied to it.
maybe I need to get away from the puter
Old 08-19-2009, 10:55 PM   #4
jA-Rod dat u?
On the valve body to the right side of the cartridge there is a cylinder shaped part of the casting with a screw on cap. That is the pressure balancing section inside there is a spool valve that should be moving back and forth balancing the pressures of the hot and cold. Its jammed up to one side allowing only the hot to come through.
It's quite common when a valve doesn't get used for a while.
"Fascism should rightly be called Corporatism, as it is the merger of corporate and government power."
~Benito Mussolini~
Lloyd Blankfein for President 2012 - Save Money Cut Out The Middleman!
Christina (08-19-2009)
Old 08-19-2009, 10:59 PM   #5
Hey Red that sounds like a Moen...(http://www.masterplumber.net/delta_scald.htm) the Delta doesnt have it ./..or Im way off my game tonite which is more likely.
Old 08-19-2009, 11:08 PM   #6
If its a newer single handle monitor or newer then the pressure balance is in the plastic cartridge and replacing it should do it.
Old 08-19-2009, 11:14 PM   #7
Master Plumber
lpayne1234's Avatar
stillaround that is the one in the link you posted i am talking about, I guess it could be trash in the cold side, I replaced cartridge and springs and boots.
Old 08-19-2009, 11:19 PM   #8
jA-Rod dat u?
Ah it might be me...
The pressure balancing is either going to be in the cartridge or off to the side.
I can never remember which is which on the deltas but I know it when I see it...
I've got some kinda memory block on them...
If it has this then it's on the side.
~Benito Mussolini~
Old 08-19-2009, 11:49 PM   #9
Master Plumber
lpayne1234's Avatar
Just remembered got the old cartridge out in the truck
here is a picture
Old 08-19-2009, 11:53 PM   #10
Master Plumber
lpayne1234's Avatar
another
New Delta Technology in Kit. Faucet TotalPlumber Plumbing Material and Products 17 05-17-2010 03:38 PM
Fiat shower pans, formica walls and Sayco shower valves trnplmb General Plumbing Discussion 4 09-30-2009 04:18 PM
Delta Faucet with Pex supplies user823 Plumbing Material and Products 40 06-20-2009 12:01 AM
Delta tub/shower valve help smythers1968 Residential Plumbing 44 06-15-2009 09:13 PM
Two handle Delta tub/shower valve clogged. Ron Residential Plumbing 6 07-22-2008 10:33 PM
