Got me to thinking on another post.
Mine? when soldering keep a small spray bottle filled with water.
| The Following User Says Thank You to Bill For This Useful Post: | LicensedPlumber (02-13-2011) |
Don't chew your fingernails.
| The Following User Says Thank You to Killertoiletspider For This Useful Post: | LicensedPlumber (02-13-2011) |
I'm crazy about lavatory drains, haaate callbacks! so I put dope (Rectorseal T+2) on the top of the rubber cone washer, putty between the bottom of the washer and the friction washer, putty under the trim piece in the basin, dope on the threads at the trim piece and the tailpiece threads, and dope the beveled surface on all connections of the trap - tightening the middle nut first then the tailpiece connection then the wallpiece connection all hand tight first then a final +/- 1/8 turn with the channellocks.
Crazy, but I have almost zero leaks on drains. ![]() |
Residential Plumber
Silicone anything you teflon, put a beed of silicon on waste and over flows silicone po plugs throw away that putty use silicone, just don't forget to wipe away the excess.
waterheaterzone.com
Why? I have never done that, teflon doesn't need silicone?
Water Heater Reviews and Water Heater Information |
Residential Plumber
I never use silicone [except where putty will discolor the finish]and I never have leaks,go figure.
| The Following 2 Users Say Thank You to threaderman For This Useful Post: | ap plumbing (12-15-2010), plumber p (03-16-2011) |
