moaning pipes - Plumbing Zone - Professional Plumbers Forum
Old 12-02-2010, 07:44 PM   #1
3KP
Plumbing Contractor
3KP's Avatar
View 3KP's Photo Album My Photos
Default moaning pipes
Went house today and the home owner said his pipes moan. So they took me into the master bath and turned on a sink, after a few seconds started to hear moaning /squeal sound. In my 13 years almost 14 years never heard water pipes make that noise. They have a well not city water. Ever heard of such a thing?
Some people dream of success while others wake up and work hard at it.
'Have a Blessed Day!"
3KP is offline   Reply With Quote
Old 12-02-2010, 08:17 PM   #2
Plumba
Qball415's Avatar
View Qball415's Photo Album My Photos
Could be the fill valve in water closet. Was it on both hot and cold?
Qball415 is offline   Reply With Quote
The Following 2 Users Say Thank You to Qball415 For This Useful Post:
futz (12-02-2010), plbgbiz (12-02-2010)
Old 12-02-2010, 08:19 PM   #3
View greenscoutII's Photo Album My Photos
Is this something that just started happening out of the blue? Anything new recently installed?
I've seen this a few times and it tends to be a pain to diagnose. If the faucet in the master is an older type using stems with rubber washers it might be just a loose washer vibrating and causing the noise. I found that once, but it was localized to the cold side of one faucet.
Just for grins and giggles, check the water pressure. PRVs seem to fail in the full open position around here and sometimes this causes the pipes to "sing" if they are copper. I've found this to be the case a couple of times when the problem just developed spontaneously and the whole house seems to be affected.
One time, it was the damndest thing, HO had installed his own water heater. The moaning pipe situation happened shortly thereafter. When I disconnected the heater (shut offs on both hot and cold) the moaning stopped. I looked inside the dielectric nipples and they had some kind of rubber disc installed inside. I pulled the dielectrics and installed 3/4 X 4 brass nipples and the problem disappeared... Weird stuff...
Anyway, hope this helps!
greenscoutII is offline   Reply With Quote
The Following 2 Users Say Thank You to greenscoutII For This Useful Post:
130 PLUMBER (12-02-2010), Protech (12-02-2010)
Old 12-02-2010, 08:21 PM   #4
AKA house plumber
Optimus Primer's Avatar
View Optimus Primer's Photo Album My Photos
hot line rubbing on something maybe
Optimus Primer is offline   Reply With Quote
Old 12-02-2010, 09:37 PM   #5
I Married Up
plbgbiz's Avatar
View plbgbiz's Photo Album My Photos
Mansfield 08 Ballcocks are notorious for this.
The self-made man is just a boy that won't say who helped him.
Thanks Dad.
plbgbiz is offline   Reply With Quote
Old 12-02-2010, 09:43 PM   #6
View Ishmael's Photo Album My Photos
Is there an anti-sweat tempering valve serving the toilet? The old Beacon 610's can cause that (I think they're made by Raven now, or maybe Legend). Could also be a loose washer in one of the faucet stems.
Ishmael is offline   Reply With Quote
Old 12-02-2010, 10:34 PM   #7
stillaround's Avatar
This probably has nothing to do with the above situation but I had one where the dual check at the meter made a moan that was heard in the house copper piping.
Government does not solve problems; it subsidizes them.
Old 12-02-2010, 10:43 PM   #8
View beachplumber's Photo Album My Photos
I agree with some of the above post.
see if u can isolate it to hot or cold of the faucet
or one of the stops
beachplumber is offline   Reply With Quote
Old 12-02-2010, 10:47 PM   #9
I Like Tater Tots
Pipe Rat's Avatar
View Pipe Rat's Photo Album My Photos
9 3/4 times out of ten the homeowner has throttled down the stops thinking they are saving on water. Combine that with a loose washer and your pipes will sing like a canary.
"The fitting in question is the one that is threaded onto the galvanized piping and looks like a peice of pipe with a bubble in it."
"Yes but in 1950 i bet the water pressure was lower than now so m copper could hold up."
Pipe Rat is offline   Reply With Quote
The Following 7 Users Say Thank You to Pipe Rat For This Useful Post:
130 PLUMBER (12-03-2010), 422 plumber (12-04-2010), Epox (12-02-2010), greenscoutII (12-02-2010), Protech (12-03-2010), Redwood (12-03-2010), Shuanvon (12-03-2010)
Old 12-03-2010, 03:06 PM   #10
MAC
MAC's Avatar
View MAC's Photo Album My Photos
I had a call like this it turned out to be the pvc drain was run through holes too tight and would moan and squeak as they expanded when the hot water was running.
MAC is offline   Reply With Quote
The Following User Says Thank You to MAC For This Useful Post:
burning pipes Gibson General Plumbing Discussion 1 02-14-2010 09:52 AM
Uh...hello, i think my pipes are frozen!!! super plumber Plumbing Pictures 8 10-12-2009 01:35 AM
Rough in pipes packers1 General Plumbing Discussion 25 09-24-2009 05:48 PM
My pipes froze!! Bill General Plumbing Discussion 15 01-19-2009 02:05 AM
