isometric drawing help - Plumbing Zone - Professional Plumbers Forum
Old 09-07-2011, 10:23 PM   #1
revenge's Avatar
View revenge's Photo Album My Photos
Default isometric drawing help
I am trying to learn how to draw a proper isometric drawing. I can read them perfectly fine but when it comes to drawing them o boy I have pipes pointing in all sorts of directions lol. By and chance can anybody help with this i really need the practice, Thanks in advance.
revenge is offline   Reply With Quote
Old 09-07-2011, 10:27 PM   #2
Illinois Licensed Plumber
SewerRatz's Avatar
Use Isometric Graph paper, it helps a lot. here is a site you can print your own for free. http://www.waterproofpaper.com/graph...ic-paper.shtml
The Following User Says Thank You to SewerRatz For This Useful Post:
johnlewismcleod (01-01-2013)
Old 09-07-2011, 10:43 PM   #3
revenge's Avatar
Thanks partner, that will help but i still having problem drawing it any tricks, you know would help
Old 09-07-2011, 11:32 PM   #4
View TX MECH PLUMBER's Photo Album My Photos
Ok revenge I know a very easy way to draw. First you make a compass on the top of the paper , but you add a up and down line and rotate your normal compass... It sounds stupid but it works when you draw the east west north and south you draw them at a 45 degree angle some say 30 degree but ether will work for a starter drawing.... Now you have your compass and north can be where ever you want it, it doesn't matter at all But if you are drawing for a real job I'd make it match the site plan. If drawing a sanitary drain system you put a line with a S on the edge of the paper to represent the sewer and where your drain will run to So now you start with a main trunk and what ever direction it goes in the building you draw it parallel to the line in the compass for that direction so a riser or drop will always go up and down. When I practice I always put north on one of the top sides of my compass...draw a main then any branch lines . All lines will be parallel to one of the compass lines after branches draw risers witch will go up and down on the paper . And draw fitting directions like a wye or combo and San tee. Then draw vents in dashed lines. Its hard to explain like this but I tried. I ways amazed when a was shown and drew a lot to practice for my test. But wasn't required to draw for test just drew to make a parts list for the doll house Don't hesitate to pm me if you want more explanation ..... Here's a crappy drawing with out fittings but the compass is the key for this method. Jut draw all lines to mach it and you will end up with a 3d drawing
TX MECH PLUMBER is offline   Reply With Quote
The Following 4 Users Say Thank You to TX MECH PLUMBER For This Useful Post:
eliorene2000 (04-24-2013), MacMech (02-04-2013), mtfallsmikey (08-16-2016), Thekid (04-24-2013)
Old 09-07-2011, 11:46 PM   #5
revenge's Avatar
Thanks tex helped out a bunch i heard for the master you no longer play with the doll house. but they do want an isometric so i gotta learn how to do and if they do make you play with the doll house gona be kind of hard to do with out knowing how to draw an isometric. Gots to start learning quick btw. When i took my journey man i did a basic drawing for drain, basic for vent and passed it fairly easy. but the master i heard its 26 fixtures. I dont think my way gonna work this time.
Old 09-07-2011, 11:57 PM   #6
I'd suggest take a prep course from Jonny curtin He is on the boards web site he use to be a state examiner and helped rite the test He has a prep class for masters with fixtur units water and drain venting combustion gas , natural gas and all that crap you have to know I took the required training for journeyman test from him and made a 100 on dollhouse 98 on shop and 97 on written He let's you know what to study and what not And yes masters is a 3 story house one day test www.txplumberprep.com. Is his website. I strongly recommend him and will be taking his prep class on 2 more years
Old 09-08-2011, 03:30 AM   #7
Pipecommandor's Avatar
View Pipecommandor's Photo Album My Photos
Nice job TX, that's exactly how I was taught !!
Pipecommandor is offline   Reply With Quote
Old 09-08-2011, 08:20 AM   #8
Thanks,,, I was wondering if it was a popular method .... Really cool how it works hu ?
The Following User Says Thank You to TX MECH PLUMBER For This Useful Post:
Thekid (04-24-2013)
Old 09-08-2011, 09:51 AM   #9
Isometrics are not that difficult once you get the hang of it. You will need to practice.
All vertical pipes such as waste stacks and vents, are also vertical on your isometric paper.
All horizontal pipes are drawn on a 30 degree angle on iso paper.
You need a '30-60-90' triangle in order to draw isometric drawings. You'll also need isometric paper.
The Following 5 Users Say Thank You to Tommy plumber For This Useful Post:
130 PLUMBER (09-19-2011), bizzybeeplumbin (09-19-2011), eliorene2000 (04-24-2013), GAN (12-28-2012), mtfallsmikey (08-16-2016)
Old 09-08-2011, 11:39 AM   #10
Those loom great Tommy I wasn't sure if it was 30 or 45. Can you get that paper at any office supply ??
Tags
isometric
Isometric Drawings markb Plumbing Pictures 26 08-18-2010 08:39 AM
Isometric Drawings? Ron General Plumbing Discussion 13 11-23-2009 08:40 PM
please help correct my plumbing/vents drawing Nittaya General Plumbing Discussion 4 10-23-2009 09:28 AM
Posting a drawing rogeru Plumbing Pictures 5 05-19-2009 08:53 PM
