Old 06-15-2010, 03:50 PM   #1
Protech's Avatar
Default I think I may have solved the mistery....
Back in mid-2009 dunbar plumbing (known as roast duck at that time) posted some pics of a water heater with out of plumb heater connections at the top. I believe the cause of the failure was water hammer.
Read here: http://www.hotwater.com/bulletin/bulletin11.pdf
Old 06-15-2010, 03:52 PM   #2
Protech's Avatar
"Water hammer is the destructive forces, pounding noises and vibration in a piping
system when water flowing through a pipeline is stopped abruptly. When water
hammer occurs, a high intensity pressure wave travels back through the piping
system until it reaches a point of some relief. The shock wave will then surge back
and forth between the point of relief and the point of stoppage until the destructive
energy is dissipated in the piping system. The violent action accounts for “banging”,
“thumping”, and/or intense vibration in the pipe line. Although noise is generally
associated with the occurrence of water hammer, it can occur without audible sound
or noise. Quick closure always causes some degree of shock with or without noise.
The common cause of water hammer is single lever faucets (sinks/lavatories) or
automatic solenoid valves (dishwashers, washing machines, etc.). The speed of the
valve closure time is directly related to the intensity of the surge pressure."
"The damage from water hammer can manifest itself in a number of ways. The most
common are:
Expanded Tank Shell - This can be demonstrated by measuring the circumference at
various locations along the shell. Pressures in excess of the maximum design working
pressure can cause permanent deformation of the shell
Collapsed Flue Tube - This will choke off the ability to vent the products of combustion
causing the flame and/or combustion to spill out from the combustion chamber. Often
this will occur where thinning of the flue tube walls has occurred due to contamination
of the combustion air or because of excessive condensation
Inverted or Deformed Tank Heads - Often this accompanies collapsed flues, but one
or both heads can be deformed."
Old 06-15-2010, 05:20 PM   #3
[quote=Protech;120658]"Water hammer is the destructive forces, pounding noises and vibration in a piping
system when water flowing through a pipeline is stopped abruptly. <snip>
All new homes we have done for the past 13-14 years have had thermal expansion tanks installed as all new houses have backflow valves. Not RPZ or testable double checks. The muncipal authorities install Watts # 7's Now the placement of the tanks was where the water came in on the house side of the meter. This did two things, took care of the thermal expansion, but also gave each house a shock absorber. Now older homes are getting a meter changeover with backflow. We have an inspector here [yep there charging a $54.00 permit fee to install a tank] that won't allow a tank to be installed if there is a valve between the tank and the water heater.
So the placement at the meter in that township is null and void. Couple that with the one authority increasing static pressure to 100+ PSI means that all tank jobs will also need a PRV. People [HO] don't understand the cost or why as a plumber I was constantly being asked questions. I put a page on the web site now they can read it
take a look ....
www.parrsplumbing.com
click on ... A little of this and a little of that
Old 06-15-2010, 05:31 PM   #4
Thermal expansion can cause the same.
Old 06-15-2010, 06:55 PM   #5
Protech's Avatar
I don't see the cpvc handling the kind of static pressure it would take to deform a tank. Now if it was a galvanized system it would be a different story.
Old 06-16-2010, 02:43 AM   #6
View PlungerJockey's Photo Album My Photos
As much as it hurts, I agree with him
PlungerJockey is offline   Reply With Quote
Old 06-16-2010, 11:29 AM   #7
View grandpa's Photo Album My Photos
I don't know whose technical bulletin that is, so I will take it a face value. I would not have expected water hammer....normally a brief occurrence...to cause deforming of the shell. So be it.
One thing I have seen for sure....at HD when water heaters come off the truck, they are 4 to a pallet and I have peeked back into receiving and seen them stacked 5 pallets high. Those heaters on the bottom of the stack are tweaked! I have seen wh out in the store with the nipples bent, and I assumed it was from the stacking.
grandpa is offline   Reply With Quote
Old 06-16-2010, 12:39 PM   #8
www.DunbarPlumbing.com
DUNBAR PLUMBING's Avatar
I've encountered this problem more than once...and I actually have a few pictures of the ones I replaced, somewhere on my hard drive.
I'm not sure what caused it....but I'm thinking heat and a serious negative force. I've even seen the tops and bottoms bubbled out like a soda can in a freezer.
All I can say that most times, high pressure was part of that equation almost always, and there was no check valve at the meter or otherwise.
I was thinking possibly a hard pressure loss from hydrant cleaning or nearby fire where the fire department was called upon to save lives, and hence the hard drop in pressure without protection to the plumbing systems.
Old 06-16-2010, 03:42 PM   #9
Protech's Avatar
So vacuum damage then?
Old 06-16-2010, 03:46 PM   #10
Read here...all of it: http://www.hotwater.com/bulletin/main4.html
Tags
water hammer, water heater, water heater failure
