Old 03-09-2009, 09:35 PM   #1
Protech's Avatar
Default Geo-Thermal
Mind talking about the geo job? I've been interested in geo for a while. None of your competitors can see in the bussines lounge. Well, unless they knew in advance and posted 250 times between now and award.
Old 03-09-2009, 10:26 PM   #2
ILPlumber's Avatar
I don't mind. I won't talk $$ till after 2:00 on the 12th
Old 03-09-2009, 10:47 PM   #3
Protech's Avatar
Fine by me. What is the geo unit for? Commersial, resi? Is it multi purpose? What kind of loop are you going to use?
Old 03-09-2009, 11:35 PM   #4
ILPlumber's Avatar
High School. there are 90 wells going to 71 heat pumps. Also 2 - 750,000 btu condensing boilers for those cold days. The heat pumps are all pretty small using either 3/4" or 1" lines. There are also 7 RTU's with 1.5" - 2.5" lines off the loop.
The loop is 6" HDPE fused connections. It holds a butt-load of fluid. I'm presently torn between $4000 worth of methanol and a feed tank for the system or $14,000 for propelyne glycol and a 1" RPZ hooked directly to the loop with PRV and fast fill. $10,000 isn't a terrible amount of money on this job.
Old 03-10-2009, 12:00 AM   #5
Protech's Avatar
Doesn't the glycol transfer heat more effectively than methanol? Why propyl and not ethyl glycol?
When you say "the" loop, I guess that means its a common loop to all the heat pumps? How is it piped?
Are the heat pumps only providing space heating and cooling, or are you heating DHW with de-superheaters as well?
Sorry if I’m hammering you with questions but it’s not often I get to pick someone’s brain about this type of thing.
Old 03-10-2009, 12:01 AM   #6
Protech's Avatar
one more. what is rtu?
Old 03-10-2009, 12:16 AM   #7
ILPlumber's Avatar
Glycol jumps to 25% to have equal heat transfer properties as 15% methanol. Propelyne is a food grade product. Super safe. You can drink it. Ethylene makes you a little bit dead if ingested.
The 6" loop runs around the entire perimeter of the building. Each heat pump has 2 taps. A supply and a return. Each heat pump has it's own pump module to pull fluid out of the loop as needed. Domestic hot is still a stand alone system. 1 100 gallon 199,000 btu WH at each facility with a 500 gallon holding tank.
Old 03-10-2009, 12:16 AM   #8
ILPlumber's Avatar
roof top unit.
Old 03-10-2009, 12:25 AM   #9
Protech's Avatar
Interesting. So I guess there is a main circulator pump that moves the main run of the loop?
Doesn't propylene break down after a while and then it needs to be changed? I know that is always a concern when designing an indirect solar system. Maybe it doesn't matter as much in geo do to the mild temps?
Old 03-10-2009, 12:22 PM   #10
Ron
Ron's Avatar
Thread bump to show as new thread.
ABS Thermal Contraction steven723 General Plumbing Discussion 16 01-21-2009 10:14 PM
