floor mounted urinal - Plumbing Zone - Professional Plumbers Forum
Old 02-28-2011, 04:02 PM   #1
View albertaplumber's Photo Album My Photos
Default floor mounted urinal
Hey guys,
I am bidding on a custom home where the owner wants a floor mounted urinal. Have never put one of these in before, (done a few wall hungs) and am wondering if anyone can give me some info on the drain hookups. What size of line does it need, how is it sealed? Is it similar to a toilet flange?
Any help would be appreciated,
Thanks
albertaplumber is offline   Reply With Quote
Old 02-28-2011, 04:20 PM   #2
View sikxsevn's Photo Album My Photos
It's been a while since I set a floor mounted urinal, but the last one I did te drain was connected with a rubber push on gasket, like a floor drain. The urinal itself was not trapped, so it needed a p trap in the rough-in
Two brackets on the wall like a normal urinal, secured to floor and drain with concrete. Major PITA to set a floor mounted urinal if you ask me
sikxsevn is offline   Reply With Quote
The Following User Says Thank You to sikxsevn For This Useful Post:
albertaplumber (03-01-2011)
Old 02-28-2011, 05:00 PM   #3
View 1703's Photo Album My Photos
I think the kohler number is k-4920.
Google that and you should find some intallation instructions.
Is this going to beon a wood framed floor?
1703 is offline   Reply With Quote
The Following User Says Thank You to 1703 For This Useful Post:
Old 02-28-2011, 05:58 PM   #4
You're going to need to box out where it is going, the easiest way to set them is in a bed of sand and let them tile it in. We always yarn and pour the drains on them, even if the waste is done in PVC.
The Following 4 Users Say Thank You to user4 For This Useful Post:
130 PLUMBER (03-01-2011), albertaplumber (03-01-2011), ILPlumber (02-28-2011), Pipe Dreams (02-28-2011)
Old 02-28-2011, 06:50 PM   #5
Special Member
Pipe Dreams's Avatar
View Pipe Dreams's Photo Album My Photos
It depends on the urinal. I've installed one that required a 3" trap under the floor and others that were 2". Your best bet is to find out the make and model and print out the spec sheet. Almost all floor models have to be installed on the rough, that I can tell you.
Pipe Dreams is offline   Reply With Quote
The Following User Says Thank You to Pipe Dreams For This Useful Post:
Old 03-01-2011, 03:13 AM   #6
Thanks for the info guys.
It is going to be installed on the main floor of a house, so I have easy access during the rough in to do whatever I need to. I was considering if installing it at rough in would be the way to go, looks like that is the case, eh?
I was going to quote an Am Std, but can't find anything on them to tell me if they need a 2 or 3 inch drain. Tried calling their customer service line, but that was a waste of 20 minutes!
I think I have half an idea now, enough that I am confident in throwing a number into a quote. The guy wants it in his kids bathroom, so his little 2 yr old can get used to taking a leak in/on one before he goes to school! I still get suprised by what people will spend money on/for!
~ We aren't retreating, we are just advancing in a different direction! ~
Old 03-01-2011, 09:12 PM   #7
First, get the spec sheet for the fixture going in, then box it out on the rough with the right size drain pipe stubbed into the box, make your box ten inches larger than the footprint of the urinal. Discuss with whoever is doing the floors the need to install the flooring to leave a void where the urinal is going on the trim to accommodate it, and why. Rough in the water for the flushometer at the right location, and leave the urinal off till the trim, where you can have it on site to double check the drain dimensions, then open your box out, set the trap and riser to match the urinal, fill the box with play sand, set your urinal, install the flushometer, and let the floor installer finish his floor.
This prevents an expensive urinal from getting ruined during the rough, and minimizes the amount of work required to install it on the trim, while still providing a seamless, quality installation.
Chicago code does not allow floor mounted urinals though.
Old 03-01-2011, 10:27 PM   #8
Special Member
A quality installation is to install the urinal on the rough and let the tile guy tile up to the urinal locking it in place. I don't know many tile contractors that are going to tile everything but around the urinal and then come back after your done with your finish and fill in the gaps.....
Do you install standard 5' bath tubs on the final too to avoid damage? I hear you can slide them right into place and add a little silicone.
Old 03-01-2011, 10:34 PM   #9
Bathtubs are not made out of vitreous china.
Urinal Trap retired rooter General Plumbing Discussion 5 05-31-2010 01:05 AM
Shower valve with tub spout mounted low TheMaster Residential Plumbing 3 03-29-2010 03:49 PM
Best Urinal Ever pdxplumber General Plumbing Discussion 13 01-04-2010 12:31 AM
Wall hung American Standard wall mounted leak pchuckie Commercial Plumbing 16 06-06-2009 11:52 AM
