Disolving urine salts? - Plumbing Zone - Professional Plumbers Forum
Old 06-26-2010, 12:12 AM   #1
rocksteady's Avatar
Default Disolving urine salts?
Is there anything that can dissolve heavy urine salts and won't damage the porcelain? I just picked up a 1937 Standard toilet that I'd like to clean up for a customer that's restoring a 30's era home. It's got mid-heavy salt build up in the trap. I've got time to soak it so it doesn't have to be a quick process. The stuff I've used in the past will stain the fixture pink if left for too long so I don't want to go that route. Is vinegar strong enough if it soaks for a few weeks?
Paul
Rocksteady Plumbing
(805) 237-7625 (ROCK)
Old 06-26-2010, 12:35 AM   #2
Illinois Licensed Plumber
SewerRatz's Avatar
Calci Solv best stuff ever. http://www.nucalgon.com/products/plu...calcisolve.htm
We been using this for years in water closets. After poking the flush jets clean, I pour quart down the overflow, and let it sit for 15 minutes to disolve the deposets. Water closet flushes like brand new afterwards.
The Following User Says Thank You to SewerRatz For This Useful Post:
Plumbducky (06-27-2010)
Old 06-26-2010, 01:12 AM   #3
rocksteady's Avatar
That's the stuff I've used before but it stains if left for too long. Maybe I'll give it a try and just make sure I don't space out and leave it in there for 2 weeks.
Don't put your head in the bowl when you pour that stuff in though, the fumes might kill you. I actually know a guy that was cleaning a few urinals in an office building with Calci Solv and a Haz-Mat crew showed up. The fumes were pulled into the ventilation and the employees started feeling ill.
Paul
Rocksteady Plumbing
Old 06-26-2010, 01:15 AM   #4
SewerRatz's Avatar
Paul
Agreed, the fumes of this stuff will knock your dick right in the dirt if you are not carefull. But it is great stuff. I have yet to find anything that works better.
Old 06-26-2010, 02:06 AM   #5
www.DunbarPlumbing.com
DUNBAR PLUMBING's Avatar
Calci-Solve <> Muriatic Acid <<< Same product, check MSDS specs
Muriatic Acid doesn't have the food coloring, and a hell of a lot cheaper.
Add it to any slow urinal and watch it foam, it will get by on a temporary.
Full tank of water in the tank, straight down the overflow and duct tape the bowl rim jets will bring any old toilet back to life, cleaning the bowl rim jets back to the original without calcium.
Brought back a ton of colored toilets that people didn't want to lose in a switch to a new toilet.
The Following User Says Thank You to DUNBAR PLUMBING For This Useful Post:
breid1903 (06-26-2010)
Old 06-26-2010, 09:30 AM   #6
SewerRatz's Avatar
MSDS http://www.nucalgon.com/products/plu...calcisolve.htm says Hydrochloric acid. the color is th e additive they put in there to protect the pipes and such.
Old 06-26-2010, 11:12 AM   #7
Same stuff. Google Search
I tried to get 2 of my bosses to listen, understand that you're paying 5 times more for something you can buy out of season for $1.74 a gallon.
They wouldn't listen, so they pay 5 times more to get the job done, and have to worry about staining.
I constantly look up MSDS sheets to find out what main ingredients are copied and dressed, made more expensive for the idea of profit. Calci-Solve is expensive.
Old 06-26-2010, 01:18 PM   #8
rocksteady's Avatar
Well, I know what Calci Solve does so I'll pick up a gallon of muriatic acid and see how well it disolves this gunk. If it can clean this bowl then I'll be a believer.
Paul
Rocksteady Plumbing
The Following User Says Thank You to rocksteady For This Useful Post:
Redwood (06-26-2010)
Old 06-26-2010, 01:23 PM   #9
Paul
It will work...
Just make sure the ventilation is good...
Better Yet Take it Outside...
~Mark Twain~
The Following 2 Users Say Thank You to Redwood For This Useful Post:
breid1903 (06-26-2010), DUNBAR PLUMBING (06-26-2010)
Old 06-26-2010, 02:16 PM   #10
Originally Posted by Redwood View Post
It will work...
Also,
any bright finishes, chrome or brass.....will get a cloudy look on the finish if you do it indoors.
Muriatic acid is great for dipping older faucet stems and getting them super clean. It'll turn them reddish in color but it'll be clean, depending on how many times you dip them.
Been using muriatic acid for years.
If you have thick buildup, you're going to have to do things to break up some of the encrustrations along the way.
rodent urine plumr Residential Plumbing 9 02-09-2010 01:42 AM
Urine and galvanized pipe... Guitpicker Commercial Plumbing 11 07-18-2008 10:04 PM
