45 Rolling Offset Formula ?? - Plumbing Zone - Professional Plumbers Forum
Old 12-02-2008, 10:50 PM   #1
para1's Avatar
View para1's Photo Album My Photos
Default 45 Rolling Offset Formula ??
Does anyone know the formula for finding the length of pipe (TRAVEL) between two 45"s. Thought I could remember it but I was wrong.
www.paradiseplumbinganddrains.com
ft. worth plumber . plumber dallas . keller plumber . plumber benbrook. plumber arlington
para1 is offline   Reply With Quote
Old 12-02-2008, 11:07 PM   #2
every tool is a hammer
422 plumber's Avatar
View 422 plumber's Photo Album My Photos
Multiply the center to center by 1.41, the subtract the fittings, I think. I used to do it every day for sump pumps, but It's been too long.
Just a sinner saved by grace
You're a funny guy,but in a scary kind of way
422 plumber is offline   Reply With Quote
The Following User Says Thank You to 422 plumber For This Useful Post:
johnlewismcleod (12-31-2012)
Old 12-02-2008, 11:40 PM   #3
Professional Bullshioter
ILPlumber's Avatar
Yup, that's it. I use it almost every day. Bugs the crap out of me to see a journeyman holding a 45 up guessing a traveler.
Buy the pipefitters and pipe weldors handbook. VERY handy book.
Typed with one hand. I'm chained to a kitchen table trying to make a sale.
The Following User Says Thank You to ILPlumber For This Useful Post:
seanny deep (02-12-2012)
Old 12-03-2008, 12:18 AM   #4
new nickname:Quaker State
Plasticman's Avatar
View Plasticman's Photo Album My Photos
Worked for a guy who said he fired his leed plumber for trying to hold up 2, 4 inch no hub 1/8 bends and measure between them at the same time. AND was on a ladder.
Plasticman is offline   Reply With Quote
Old 12-03-2008, 03:06 AM   #5
www.DunbarPlumbing.com
DUNBAR PLUMBING's Avatar
We always had to do a copper jig for the journeyman's test, using the multiplier 1.414 and now they have instead of a lead pour,
3 pipes that are 2" cast iron, ou have to figure out how the offsets work and do your multipliers and if you're right, when you slip on the mission couplings they are either super tight or don't fit at all.
Old 12-03-2008, 03:11 AM   #6
View Wethead's Photo Album My Photos
Google Books has it for ya
Plumber's and Pipe Fitter's ... - Google Book Search
Even has pictures
Wethead is offline   Reply With Quote
Old 12-04-2008, 08:54 PM   #7
A rolling offset is not a simple offset.
In a rolled offset you need to know the spread A and the advanceB, then it is a simple formula, A squared, plus B squared, the suare root of that sum is then multiplied by 1.4142 and the fitting takeoffs subtracted from that number. that formula is for 45 degree offsets for 60 degree offsets replace 1.4142 with 1.1547, the rest is the same.
Old 12-05-2008, 01:07 AM   #8
Thats only done when you have an air computer...
Sheeesh!
Epox (12-01-2012)
Old 12-06-2008, 04:35 PM   #9
View Marlin's Photo Album My Photos
That's how I was shown how to do it. Their is a formula? That makes my life a little easier.
Marlin is offline   Reply With Quote
Old 12-10-2008, 04:21 PM   #10
This space for rent
Double-A's Avatar
View Double-A's Photo Album My Photos
Um... you folks are making things complicated and Killer, I'm not sure what the heck Spread and Advance refer to.
Think of a right triangle, 45, 45, 90. The two short sides are equal. The long side is calculated by using the
Pythagorean theorem. The three sides are A, B, and C, so A squared, plus B squared is equal to the square root of C.
Now, think of a vertical pipe that needs to offset 6 inches. You use the 6 inches and multiply by 1.4142, and that will give you the center line to center line distance between the two pipes along the path of your angle, or 8.48 inches, which rounds to the nearest 1/16th of an inch, or 8-1/2". You have to compensate for the fitting make up distance, which is subtracted from that length.
BTW, your offset will always equal your rise and visa versa in a 45,45,90 triangle.
A picture is worth a thousand words so...
If you were to do as Killer says, 6x6=36, 36+36=72, the square root of 72 = 8.48528. If I then multiply that by 1.4142, I come out with something just under 12. That won't work, even after I subtract for the fitting make up. That's why I got lost.
Just multiply the offset by 1.414 and then knock off the fitting allowances or make up and it'll fit like it was made to go there.
"My clients’ wishes are the center of my attention." -- David Guido, a contractor in Woodstock, N.Y.
New York Times, July 20, 2006
Double-A is offline   Reply With Quote
The Following 3 Users Say Thank You to Double-A For This Useful Post:
ColbyCheese (02-03-2011), DIZ (03-18-2011), johnlewismcleod (12-31-2012)
Tags
piping offsets
Rolling Stock Double-A General Plumbing Discussion 9 08-21-2008 12:34 AM
