4 inch pvc check valves - Plumbing Zone - Professional Plumbers Forum
Old 04-12-2009, 10:29 AM   #1
Bollinger plumber's Avatar
View Bollinger plumber's Photo Album My Photos
Send a message via MSN to Bollinger plumber Send a message via Yahoo to Bollinger plumber
Default 4 inch pvc check valves
Just want to know how you guys feel about 4" pvc check valves in sewer lines. We have a company here that really pushes them. My experience with them is that they seem to cause more problems than they solve. I guess if the ho would take the time to clean them or have them cleaned once in a while they would be ok but they almost never do. Plus if I don't know they are in there I tend to get my snake stuck in the line. The only place I could see using them would be if you are the low house on the block. and even then I have reservations about them. This company makes it sound like if you have a check valve in your line you will never have a flooded basement again which we all know that is a bunch of crock. This is the same company that I talked about in my other post about lying to customers.
http://alsdrainservice.services.offi...m/default.aspx
Only two devining forces have died for you. One is Jesus Christ and the other is the American soldier. One died for your soul the other died for your freedom.
Bollinger plumber is offline   Reply With Quote
Old 04-12-2009, 10:50 AM   #2
Cal
Cal's Avatar
View Cal's Photo Album My Photos
NO THANK YOU !!! If you have problem floor drain or such ,,, use a flood guard fitting for that drain . I think a main line check is just a problem LURKING !!
Cal
Cal is offline   Reply With Quote
Old 04-12-2009, 12:28 PM   #3
Plumbing Contractor
uaplumber's Avatar
View uaplumber's Photo Album My Photos
This is what we install.
No issues with snakeing
Only blocks line during back flow.
Mainline Backwater valve.
B&B Plumbing Inc
Plumbing and Heating in Westlock, Alberta
uaplumber is offline   Reply With Quote
The Following User Says Thank You to uaplumber For This Useful Post:
Plumbworker (04-12-2009)
Old 04-12-2009, 10:13 PM   #4
View Herk's Photo Album My Photos
Backwater valves are required here under UPC for any basement fixtures. Upper floors do not go through the backwater valve. Personally, I thought it was an idiotic move because of problems with plugged lines, but the state in their infinite wisdom made it law.
Herk is offline   Reply With Quote
Old 04-13-2009, 02:11 PM   #5
I do not favor the installation of check valves but there are often sewer systems of an area that may be succeptable to frequent back up. Particularly those in areas with combined systems during storms where the addition of storm waster to the sewers overwhelm the system design.
Maintainance of the check valve is often a problem as the access is often difficult. My preference if a valve has to be installed would be this one where servicing is done from a clean out at ground level vs. a manhole.
http://www.cleancheck.com/
Old 04-14-2009, 12:52 AM   #6
I love that one, Redwood! What a great idea.
Old 04-14-2009, 08:43 AM   #7
Drain Cleaning Specialist
UnclogNH's Avatar
View UnclogNH's Photo Album My Photos
I love check valves. Especially when there full of baby whipes and buried with no access.
Charging less does not mean more call volume it just means you have to work harder to reach your goals.
UnclogNH is offline   Reply With Quote
Old 04-14-2009, 09:32 AM   #8
Yes I agree with you there. My question is though would you recommend them to be installed in a line? I can see some circumstances where it would do good like being the low man on the block and the city sewer backs up or like someone else mentioned where rain water becomes a factor. but this is only if the valve is cleaned on a regular basis. Which I don't see that happening. This ad I talk about makes it sound like if you install one you will never have water or sewage backing up in your basement. I don't see that happening. misleading ads like this make it hard to try and explain to a ho that if you flush g i joe down your sewer line you will have sewage in your basement if you continue to use your plumbing or if you have a running toilet or faucet.
Old 04-14-2009, 09:45 AM   #9
UnclogNH's Avatar
Yes, I do believe they are good, and very useful as long as they are properly maintained with access. Definitely if someone is the low guy on the street they need one. just makes someone else the low guy and they need one to and so on and so on. $$$$ if you can sell them to everyone.
But regardless everyone's sewer will back up atleast with a back flow preventer they can control how much they flood and can stop usage. The City line on the other hand can keep on coming up big mess
Old 04-14-2009, 11:07 AM   #10
View Airgap's Photo Album My Photos
If I know they are there, okay. I don't like to find them the hard way.
AG..Keepin' the good water from the bad water....
Airgap is offline   Reply With Quote
Gate Valves Or Ball Valves-vote! WestCoastPlumber General Plumbing Discussion 73 01-12-2013 08:41 PM
Check your load. Bill Drain and Sewer Cleaning 7 02-22-2009 07:27 PM
Spell check Bill Off Topic (Non Trade) 2 07-13-2008 10:22 PM
