What type do you keep with you even knowing you may not use it much.
I try to keep taps for mip adapters. Do not use them much, but had a few times when after the drywall was finished and cross threaded a nipple. Comes in handy. Also I have added a pipe extractor I guess you call it. Fits on a drill and runs pvc pipe out of the hub.
I carry a couple of taps for closet bolts, get some cast flanges that the bolts will just break off from trying you remove them, drill it out just a tad smaller and re-tap it, install new bolts, and ready to set the toilet.
I carry a complete tap and die set, metric up to 13mm and standard up to 1/2 coarse and fine.
I carry a complete set of pipe taps from 1/8" to 2", with matching dies. I have a complete set of caulking irons for packing lead joints, including offset irons, and running ropes for up to 15" CI. For a some reason that I really can't think of I carry my little tool box with all the tools needed for wiping lead water service joints, complete with turnpins, a shave hook, wiping cloths and candles, and a two inch ladle. |
I do carry a 1-1/2 Pipe Tap, to chase the thread on a rusty durham tapped tee.
J. McCabe Plumbing Inc.
I learned a trick from an old Dutch plumber friend of mine about 25 years ago. He would cross cut, about 1/2-3/4", down into the end of a 6" long steel nipple. The cut nipple then acts like a pipe tap, as the nipple is allowed to collapse a little and the sharp edges of the cuts clean out the tapped durham thread. Works great so I usually carry a 2" and a 1-1/2" at all times. Cheap too!
#8 | |
Ridgid tool user
Dremel but it has become one of my most used tools. I use it for just about anything-cutting off flange bolt, removing pex crimp ring, cutting off soldered angle stops, making grilled cheese sandwiches, etc.
#10 | |
Ridgid tool user
| Tools For The Trade | kellybhutchings | Plumbing Tools and Equipment | 11 | 11-20-2008 07:25 AM |
| Tools | Ron | Plumbing Tools and Equipment | 13 | 10-08-2008 10:03 PM |
| tools | se215 | General Plumbing Discussion | 6 | 09-26-2008 05:25 PM |
| Suppliers tools | Bill | Plumbing Tools and Equipment | 4 | 08-26-2008 11:00 PM |
| Battery tools | Bill | Plumbing Tools and Equipment | 14 | 08-05-2008 12:14 AM |
