Ruby Fluid liquid flux - Plumbing Zone - Professional Plumbers Forum
Old 04-05-2011, 10:58 PM   #1
every tool is a hammer
422 plumber's Avatar
View 422 plumber's Photo Album My Photos
Default Ruby Fluid liquid flux
I just bought a bottle of Ruby Fluid, I like it so far. It's a lot neater than paste flux, and you don't waste any. Vertical joints are a lot neater, there is no excess flux to run down and create a path for the solder.
Just a sinner saved by grace
You're a funny guy,but in a scary kind of way
422 plumber is offline   Reply With Quote
Old 04-05-2011, 11:51 PM   #2
www.DunbarPlumbing.com
DUNBAR PLUMBING's Avatar
Is this a 'proven' product for reliability?
Years ago, we used some type of product for a very short period of time, came in a blue container and had a brush in it like you'd see for nail polish.
It was completely clear, and there was nothing to it. Brush it on and go.
The boss at the time told us to stop using it because someone eventually had a solder joint blow apart, but it was obvious the copper pipe was never sanded before the joint was prepared.
On new copper, the product even stated that no sanding was required.
Personally, if I could trust a flux in liquid I would be willing to make a switch, only because I find the application of flux in paste form to be wasteful, uneven spreading at times and the possibility of contamination or separation in the tin.
All valid points, and hope others chime in on the matter.
The sand cloth I'm using that is being supplied at the supply houses?
Made to last a short time, nothing like years ago. And since it breaks down quite easily, it creates a dust that's obvious. Remember when a 'good' piece of sandcloth could go almost a whole day? (as long as it is kept clean)
Old 04-05-2011, 11:57 PM   #3
Lego Expert
GREENPLUM's Avatar
View GREENPLUM's Photo Album My Photos
Superior Flux
Rubyfluid
Soldering/Tinning Flux Liquid
Rubyfluid is a general purpose soldering flux for copper,
brass, tin, galvanized tin, mild steel, stained glass.
Active 200 - 600 deg.F (95 - 315 deg. C)
Contains Zinc Chloride
To remove excess flux wash finished work with warm/hot water
We recommend using solid wire solder with this flux,
this will give a stronger and cleaner joint.
Not recommended for Electronics, or Model RR Track
Use Superior No.30for Electronics & Model RR Track
UseSuperior No.71 and 78for Stainless and other Hard to Solder Metals.
2 Oz. (59ml) bottle - - - - $2.85
8 Oz. (236ml) bottle - - - - $6.50
16 Oz. (473ml) bottle - - - - $9.85
GREENPLUM is offline   Reply With Quote
The Following User Says Thank You to GREENPLUM For This Useful Post:
422 plumber (04-08-2011)
Old 04-05-2011, 11:58 PM   #4
View U666A's Photo Album My Photos
The stuff you're referring to almost sounds like "fluxolder". Remember that black ****e that boasted that you needn't clean the pipe/fittings nor even apply any solder?
Do you use sand cloth or grit cloth Dunby? Clearly the latter is better in just about every capacity IMHO.
Sent from my iPhone using PlumbingZone
U666A is offline   Reply With Quote
Old 04-06-2011, 12:17 AM   #5
Always, I don't have one solder joint out there that hasn't had the end of copper sandclothed or my fittings.
That's the issue I had with on using a clear liquid as a flux.
It's very common for plumbers to use paste, and if it is reliable, I can see a lot of positives using fluid/liquid if it is reliable. Especially when paste gets cold and is hard to spread.
But, I'm curious if this liquid holds up on copper lines where water is involved. <<< 95% of my work.
Old 04-06-2011, 08:11 PM   #6
Steve,
have you ever used scotchbrite, instead of sandcloth or gritcloth? It doesn't leave any grit behind.
Old 04-08-2011, 06:08 PM   #7
Associated Plum's Avatar
View Associated Plum's Photo Album My Photos
Ruby Fluid is used in the sheet metal business.
The best sand cloth I used was marketed by Nibco and I believe it was Red Oxide. That stuff seemed to last forever
With over 60 years of service, chances are we have seen your friend's bathroom
Associated Plumbers Inc.
www.associatedplumbers.com
http://twitter.com/assocplumbers
Like our Page @ www.facebook.com/associated.plumbers
Associated Plum is offline   Reply With Quote
The Following User Says Thank You to Associated Plum For This Useful Post:
DUNBAR PLUMBING (04-08-2011)
Old 04-08-2011, 08:44 PM   #8
We just repiped a shower room at one of the power plants. Some of the 1-1/2" joints were done with Ruby Fluid, some with No-Korrode, and some with Oatey No. 95 tinning flux. About half were prefabbed and the other half done in the shower room. No leaks, and the Ruby Fluid joints were the cleanest.
The Following User Says Thank You to 422 plumber For This Useful Post:
Old 04-08-2011, 09:05 PM   #9
I'm right your wrong
easttexasplumb's Avatar
View easttexasplumb's Photo Album My Photos
This time of the year my paste is liquid.
This is not my signature
easttexasplumb is offline   Reply With Quote
The Following User Says Thank You to easttexasplumb For This Useful Post:
Old 04-08-2011, 09:18 PM   #10
I ran out of tinning flux yesterday, now I'm using nokorode.
I think I'm going to use the recommendations soon to try something new.
My concern is what water does in the equation, and if that will keep this product from spreading effectively where it needs to be.
I contaminate my paste every time I use my fingers to spread it, or use a flux brush that constantly keeps dirty or loses bristles.
Tired of the design, and flux as mentioned is a freaking soup this time of the year when it is hot.
What Flux do you use? newbie Plumbing Material and Products 98 08-22-2012 02:24 AM
Flux after sweat marc76075 General Plumbing Discussion 34 12-18-2010 07:48 PM
Over aggressive new flux? gear junkie Plumbing Material and Products 9 11-28-2009 10:23 PM
Any sprinkler contractors? Fluid dynamics engineers? Help determine water pressure Steve Residential Plumbing 1 07-29-2009 08:13 PM
Best of the best? DOPE & FLUX !! sweetness09 General Plumbing Discussion 2 03-12-2009 01:51 AM
