I used to like my acetylene tank, but it got too cumbersome and got me a map tank 2 years ago. I love map, quick. Also I love the self start and the tip dont get hot, and much easier to carry under a house. I do however miss the smaller flame which I liked.
Map is the only tank I use, good enough the silver braze the smaller size lines also.
I have not silver soldered with map before, always my acetylene. I did not know map would heat hot enough to do that with
Propane! I thought that was a thing of the past!
yeh, but how long does it take to get say a 3/4 fitting hot enough to cause the solder to run with propane as opposed to map?
Plumber Manhattan Beach
I love the speed of acetylene, and I only use MAPP, faster then propane in my mind.
I use self starts. Anything over 3/4 gets acetylene. so 1" and up. |
waterheaterzone.com
You're kidding right? Propane is pathetic. Then again I am a service guy, so all the pipes I solder are wet....propane doesn't cut it. I started with acetylene bottles, now I use MAPP.
