I use to have a set of Jet Swets but I was out of plumbing for two years and have no idea where they went. I got $5.51 worth of supplies at Ace and will make my own. I'll let you know if it works.
You can by replacement rubber grommets from "jet sweat" to help make your own. just an idea......I'm sure you may know this!!!
I have had alot of luck with just a supply line and a rag or sponge. depending on what size line you are working on ( most of my stuff was bigger) wrap the rag around the supply or pipe and slide it in the pipe you are fixing 3" or 4" the water backs up at the rag and runs out the supply.A full port b valve or a tee adapter and plug and you are good to go. Don't work for much preasure but takes away that pesky stream that you can't chase away.
| The Following User Says Thank You to weplumb For This Useful Post: | TotalPlumber (06-24-2009) |
I made one years ago from a new cast iron bypass plug http://webstore.petersenresources.co...bodyplugs.aspx
I had to modify the 3' rubber to fit inside of 2.5" copper and used a piece of 1/2" black pipe about 3' long to get it into the pipe and to give enough sticking out for the water to drain out and away. That is one of those custom made tools that shows the ingenuity (common sense) that some of us possess and that what is lacking in most of the ones coming up in the trades today |
Plumber, Totally
Wrap a rag around 1/4" copper, Jamb the thing up inside the pipe you're working on, make sure the rag is very compressed, full-port BV slides over the 1/4" cu, and SWEAT QUICKLY! Similar to WePlumb's suggestion, 2 posts up.
Not perfect, but workable sometimes! Total |
| Jet swet | tzzzz216 | Plumbers Swap | 4 | 04-08-2009 06:36 PM |
| Jet Swet | I'mYourTourGuide | Plumbers Swap | 3 | 04-01-2009 01:48 AM |
| Jet swet clones | TDB | Plumbing Tools and Equipment | 17 | 02-19-2009 04:46 AM |
| Have you made one of these? | Song Dog | Residential Plumbing | 8 | 07-12-2008 05:02 PM |
